Previous in Forum: Dry Contacts vs. Wet Contacts   Next in Forum: How to Select Control Valves
How to Select Thermal Relief Valves
05/20/2008 6:11 AM
why do we select thermal relief valve (cooling water service) always of size 3/4" x1" only .
Re: thermal relief valve
05/20/2008 6:12 AM
05/20/2008 8:20 AM
A global engineering forum might not know why "we" select 3/4" x 1" thermal relief valve on cooling water service, as the selection may be carried out according to local customs, practices and Standards.
Er, why are thermal relief valves used on cooling water service at this particular location? Are the process cooling surfaces undersized to the extent that boiling occurs?
Register to Reply 2 comments
You might be interested in: Pressure Relief Valves, Gas Valves, Hydraulic Valves
