Previous in Forum: New Technology Improves Methanol Fuel Cell Output   Next in Forum: Natural Gas Turbine/Generator Sets
Desalinating Ocean Water for Swimming Pools
05/20/2008 2:38 PM
Some time ago, I was swimming in a pool in El Salvador with a swimming pool contractor from Canada. He told me that it was economically practical to take ocean water (salt water) and desalinate it using it in large swimming pools. I find that to be questionable as I suspect that even use of RO water from such a source to be very costly. Is his comment accurate?
Re: Desalinating Ocean Water for Swimming Pools
05/20/2008 6:10 PM
All you have to do is separate the sodium from the chlorine and you've got a fresh water self-chlorinating pool.
Good Answers: 213
05/20/2008 10:59 PM
Here in Panama, I know of a couple of installations that use raw sea water, no treatment, for the swimming pool. The water is changed daily. This seems quite a bit more cost effective than desalinating the water first, and adding chlorine. I have also heard reports, unsubstantiated so far, that there are people in the US using salt added to fresh water to maintain chlorine levels. I do not know if this is practical. What I do know is that desalinization is not generally an economical option- power required is significant.
Good Answers: 32
05/21/2008 10:07 AM
Using electrolysis to automatically generate Cl2 for pools is becoming more common. Only a small amount of salt is required in the pool water. I think it is below the level that most people can taste.
Here is one example:
http://www.poolandspashop.net/saltelec.html
Tad
05/21/2008 12:10 AM
In India we use Nuclear energy to convert sea water to potable water. The hard water of sea is passed through nuclear reactor and steam generated are cooled and is converted to potable water. This conversion is very costly issue.
Never never never give up
05/21/2008 3:14 AM
The operating cost of RO to produce swimming pool water comes out at about 4.0-4.5kWh per m3, as a rough-and-ready figure.
05/21/2008 7:15 AM
How ironic - some people pay to add salt to their pools, other people want to take it out.
Belgium - Member - New Member
05/27/2008 6:37 AM
For your info:
On board of seagoing ships, a freshwater generator (ex. mfg. Atlas Denmark - www.atlas-danmark.com ) is generally used for the production of freshwater from seawater; this desalinated ocean water is also used for the swimming pool on board. Freshwater is produced at low cost: cooling water of the main-engine is used to warm-up, under vacuum, the freshwater generator…
Best regards
John Sijs / 2 John
Tell me and I forget. Teach me and I remember. Involve me and I learn. --Benjamin Franklin--
2 John (1); Anonymous Poster (1); bhankiii (1); cwarner7_11 (1); PWSlack (1); Tad (1); vijaygr (1)
