Previous in Forum: SPI Serial EEPROM Corruption   Next in Forum: MCCB Schematics
NEC Standards for Fire Alarms, Heat Detectors, and Smoke Detectors
05/20/2008 4:33 PM
What is the recommended type of fire alarm detectors in transformar's and generator's rooms according to NEC? Heat or smoke detectors?
Thanks.
Re: NEC Standards for Fire Alarms, Heat Detectors, and Smoke Detectors
05/21/2008 5:20 AM
You can go for Edwards System Technology brand.
As Per NFPA 70 , Edwards models satisfies the spects required for fire alarm detectors in transformar's and generator's rooms.
05/21/2008 6:00 AM
Both heat and smoke detectors are required in these rooms...
05/21/2008 2:59 PM
Thanks for information, would you name please the number of artical in NFPA which state that becouse i coud't find this in particular.
Thanks for cooperation
02/01/2010 5:21 AM
regarding
heat or smoke detector required in generator rooms, will u name the related article of NFPA 72 inorder to find it particular.
all replies will be appreciated!
02/01/2010 5:55 AM
regarding requirement of smoke or heat detectors in generator rooms
will u specify the artical in NPFA 72, stating particularly requirements in generator rooms
regards
02/27/2010 3:47 AM
does anyone can help, which article in nfpa 72 states that detectors required in generator rooms, regards
01/03/2023 9:31 AM
Is this standard not to hand, then? Try buying a copy of it.
Register to Reply 7 comments
Anonymous Poster (2); bahtier (2); kldadlm (1); mangeshkakade (1); PWSlack (1)
