Hello All,
I work for a Medical Equipment manufacturer. Our equipment is sold internationally and is designed to operate on 120/240VAC, 50/60 Hz power. We use a number of Atmel 25256A serial SPI bus EEPROMS, one of which is located on a lamp assembly containing 18 fluorescent lamps, and is used to tally operating time during the interval when the lamps are in operation.
We have recently experienced several failures at a site in Rotherham, England (new site) where the data contained in the EEPROM is corrupted by one or two bits. The power there is 240VAC, 50Hz. These failures have also occurred here in the US (120VAC, 60Hz), albiet much less frequently. The failure seems to occur when to unit is either powered down or up, since the failure is only detected when the unit is powered up after running with no problems during the previous use.
At the time when the unit is shut down, the lamps are not in operation, and the operation time data is collected (EEPROM is written) only during the time when the lamps are on. The lamps are only used after the unit has been turned on for some time during the treatment cycle.
I am of the opinion that we have a power glitch that corrupts the data stored in the device, since the only way to write data into the device involves a fairly complex programming sequence.
I was wondering if anyone has had similar problems with Serial EEPROMS that were found to be due to power fluctuations.
Regards,
Ron
