Previous in Forum: coil winding   Next in Forum: electrical
Close Transition between Main Power Supply and Generator
05/22/2008 12:54 AM
Refer to the question,I would like to ask about this matters.
FYI, we ere currently installing a ACTTS , or Auto Close Transition Transfer Switch, or ATS. During the close transition (transfer load) from the main supply( In Malaysia, we are provided by Tenaga Nasional Berhad) to the Standby Generator , the power dip occured in very short time< 1second. I suspected UnderVolatge Trip at Generator, but the UnderVolatage relay not detected. hmm what actually can effect the dip? we measure the Voltage, is OK. How about undervoltage coil? or another possible caused?
Re: Close Transition between Main Power Supply and Generator
05/22/2008 5:25 AM
A standard ATS will always give a voltage dip because it disconnects the one supply from the load before transfering to the other supply. if you want bumpless tranfer you need to sychronise the supplies together before switching one of them off.
If you are using generator as mains failure only you will always get a dip
A day without a smile is a day lost
05/22/2008 8:19 AM
I presume what you observed was your standby generator being reverse powered by the grid..
The next time you transition observe your KW meter on standby genset, and look for power flow in the negative direction, also observe your reactive power (VARS) in the same fashion.. A couple of questions..
How long is your closed transition timer set for? Normally this can be very short..
How big is you standby gen set?
Good Answers: 19
05/22/2008 11:35 PM
Has the DG source tripped ?.If it is tripped then there is a problem which has to be probed thoroughly.
If it is only dip, it is bound to happen, as the Mains supply will be cut off and DG supply will be switched On in a fraction of second.
If you do not want any dip in voltage, you should first synchronise the DG supply to the Mains , transfer the loads to the DG source and trip the Mains supply.
Ramesh,Freelance Electrical/automation Consultant
05/23/2008 12:09 AM
Hi everybody, thanx to All for ur respon. After some troubleshooting, we found that no problem actually on our existing genset, the problem was caused by the new ACTTS installed. some setting on that equipment. problem eliminated already.tq once again
05/23/2008 3:24 AM
Owh...so the conclusion is setting on that equipment....
Well done.
05/27/2008 9:42 AM
Just curious, ainahamd,..but what was that "some setting"...it would be great if you can share that info with the forum members once you find it...
Cheers
He must be very ignorant as he answers all the questions he is asked. Voltaire
Register to Reply 6 comments
ainahmad (1); chaterpilar (1); ekiechle (1); nasarin (1); peterd (1); ramvinod (1)
