Previous in Forum: application of api 1104 acceptance criterion for ultrasonic testing   Next in Forum: Pressure
9 comments
litres to tons
05/23/2008 9:23 AM
How can i express 10,000 litres of water in tons?
Good Answers: 22
Re: litres to tons
05/23/2008 9:30 AM
Presumably you mean metric tons (or tonnes) rather than any of the other tons that are used around the place...
Water has a density of 1000 kg per cubic metre - which gives you 1 tonne per 1000 litres. So your 10,000L will have a mass of 10 tonnes.
This is dependent on temperature - it's about 996kg per cubic metre at 18degrees C - if you need complete accuracy get hold of the density v temperature formula for water - it doesn't range very far from the basic "1000 litres = 1 tonne" though for common temperatures.
Re: litres to tons
05/23/2008 9:39 AM
So, 10,000 litlers (10 kl) = 10 metric tons.
As a check, I use english units. 1 liter is about 1/4 of a gallon, and a gallon weighs about 8 pounds ("A pint's a pound, the world around") so yeah, a liter is a little over 2 pounds, and a kilogram is 2.2 lbs. 10,000 liters x 2.2 pounds/2200 lbs per metric ton = 10 metric tons, so it works.
Re: litres to tons
05/23/2008 10:12 AM
Arrgggggghhhhhh!!.... No please don't confuse things with gallons UK or USA and pints UK or USA measures!!!
A UK gallon is about 10 pounds and one of 'our' pint's is a pound in weight!!
John
Good Answers: 266
Re: litres to tons
05/23/2008 5:15 PM
Should we start with cups or tablespoons then?
Good Answers: 19
Re: litres to tons
05/25/2008 2:47 AM
I consider it fairly variable due to temperature, although between 0C and 25C you could get away with ignoring the density change.
Re: litres to tons
05/24/2008 5:05 AM
you can express 10,000 liters of water in tons by the following convertion:
1 liter=1kg(approx.)
1 ton(metric)=1000kgs
therefore;
10,000 liters x 1 kg/1 liter x 1ton/1000 kgs=10 tons of water
Good Answers: 101
Re: litres to tons
05/25/2008 9:55 PM
1 liter of water = 1 kilogram.
1,000 kilograms = 1 metric ton
1 metric ton = 1.1 imperial tons
10,000 liters of water = 10 metric tons = 11 imperial tons
Re: litres to tons
05/27/2008 3:57 AM
This is all that is needed.
Re: litres to tons
05/27/2008 9:48 AM
Interesting link PW...
Register to Reply 9 comments
Anonymous Poster (1); DVader1000 (1); Electroman (2); Fierce Allegiance (1); ozzb (1); PWSlack (1); Ried (1); RobertOz (1)
