Previous in Forum: second call - civil works in mining project   Next in Forum: ABUBAKAR AWAN
Good Answers: 101
Swimming pool design
05/25/2008 11:19 PM
Does anybody here know what is the usual retention time for a swimming pool balancing tank and skimmer size?
Thanks.
Pathfinder Tags: pool size skimmer swimming Tank
Good Answers: 40
Re: Swimming pool design
05/27/2008 9:42 AM
I do believe that the local Code might dictate part of your answer, as well as consideration whether 'residential' or 'commercial' pool, surface area, bather load, etc.
Good Answers: 101
05/27/2008 8:38 PM
Okay, noted. Thanks.
Register to Reply 2 comments
