Previous in Forum: Swimming pool design   Next in Forum: Shuttering and Form Work
12 comments
ABUBAKAR AWAN
05/26/2008 2:30 AM
Dear Sir,
please send me the tower foundation exact design.
Good Answers: 230
Re: ABUBAKAR AWAN
05/26/2008 3:17 AM
Hello Guest,
There are several towers with the reference: "ABUBAKAR AWAN".
Please advise which of the several towers you refer to, because we are not mindreaders.
Kind Regards....
Good Answers: 101
Re: ABUBAKAR AWAN
05/26/2008 6:24 AM
I think "ABUBAKAR AWAN" is the poster's name.
Re: ABUBAKAR AWAN
05/27/2008 4:06 AM
Abu Bakar is the name of the right hand man & successor of the Muslim prophet.
Abu Bakar is a camp in Southern Mindanao Philippines were they train terrorists, but was later captured by the Philippine government.
Is the tower going to be used as a citadel? watchtower? launching pad for rocket propelled weapons? sniper position?
Again we are not mind readers.
"It is only when we die that we become Immortal."
Good Answers: 16
Re: ABUBAKAR AWAN
05/26/2008 11:48 PM
From way back in high school I learnt about Abubakar Tafawar Belewar.
I think that the Abubakar was the name of his birth place and the tradition was that this prefixed to the name at manhood. Anyway he was another teacher who became the ruler. Unlike most he was not a megalomaniac.
http://en.wikipedia.org/wiki/Abubakar_Tafawa_Balewa
BAB.
Make it so.
Re: ABUBAKAR AWAN
05/27/2008 1:31 AM
http://cr4.globalspec.com/edit/newthread?pt=1
Regards, RF_guy
Re: ABUBAKAR AWAN
05/27/2008 7:29 AM
....another thoughtless, pointless request for free info from the "Jests" of CR4.......
DUUUHHHHH!!!!! Brother do we get them here........!!!
Re: ABUBAKAR AWAN
06/02/2008 3:09 PM
  1. Erase the "Dear Sir" and replace it with "Attention".
  2. Erase the "Please".
  3. After the word design, Add- "Immediately".
Who the hell do you think you are?
Wangito.
Never trade luck for skill.
Re: ABUBAKAR AWAN
06/02/2008 7:52 PM
Love it, really funny!!!
Re: ABUBAKAR AWAN
06/06/2008 3:45 PM
Please supply me with the blueprints for a nukyler weapon and a source for plutonium.
Thank you in advance.
Good Answers: 230
Re: ABUBAKAR AWAN
06/06/2008 9:30 PM
Hello Guest,
I may have misinterpreted the word "tower" in your Topic Post, as meaning a high building.
I have since realised you may have meant an animal or vehicle which pulls some object along, similar to a train engine, which tows the train carriages.
Or perhaps you meant some tractor vehicle, truck or similar, which tows a load of some sorts.
Or perhaps you intended a different meaning for the "tower" you mentioned.
I have earnestly and thoroughly checked all possible resources on your behalf, thinking perhaps that ABUBAKAR AWAN was the brand name of the train engine (locomotive), tractor vehicle, truck or similar.
Sadly, I have not yet been able to arrive at a definite conclusion on your behalf, with which to advise you.
Would you be able to furnish more details, as I requested in my earlier Post.
Various meanings per Thesaurus are listed as below, and it is necessary for you to clarify, so that the response to you is a correct one.
Thesaurus:
Noun
1.
tower - a structure taller than its diameter; can stand alone or be attached to a larger buildingbarbacan, barbican - a tower that is part of a defensive structure (such as a castle)beacon light, lighthouse, pharos, beacon - a tower with a light that gives warning of shoals to passing shipsbell tower - a tower that supports or shelters a bellchurch tower - the tower of a churchclock tower - a tower with a large clock visible high up on an outside facecontrol tower - a tower with an elevated workspace enclosed in glass for the visual observation of aircraft around an airporthigh-rise, tower block - tower consisting of a multistoried building of offices or apartments; "`tower block' is the British term for `high-rise'"minaret - slender tower with balconiesmooring mast, mooring tower - a tower for mooring airshipspower pylon, pylon - a large vertical steel tower supporting high-tension power lines; "power pylons are a favorite target for terrorists"pylon - a tower for guiding pilots or marking the turning point in a raceshot tower - tower of a kind once used to make shot; molten lead was poured through a sieve and dropped into watersilo - a cylindrical tower used for storing silagespire, steeple - a tall tower that forms the superstructure of a building (usually a church or temple) and that tapers to a point at the topstructure, construction - a thing constructed; a complex entity constructed of many parts; "the structure consisted of a series of arches"; "she wore her hair in an amazing construction of whirls and ribbons"supporting tower - a tower that serves to support somethingturret - a small tower extending above a buildingwatchtower - an observation tower for a lookout to watch over prisoners or watch for fires or enemies
2.
tower - anything that approximates the shape of a column or tower; "the test tube held a column of white powder"; "a tower of dust rose above the horizon"; "a thin pillar of smoke betrayed their campsite"pillar, columnshape, form - the spatial arrangement of something as distinct from its substance; "geometry is the mathematical science of shape"columella - a small column (or structure resembling a column) that is a part of a plant or animalhoodoo - (geology) a column of weathered and unusually shaped rock; "a tall sandstone hoodoo"
3.
tower - a powerful small boat designed to pull or push larger shipstowboat, tugboat, tugboat - a small vessel for travel on waterhelm - steering mechanism for a vessel; a mechanical device by which a vessel is steered
Verb
1.
tower - appear very large or occupy a commanding position; "The huge sculpture predominates over the fountain"; "Large shadows loomed on the canyon wall"hulk, loom, predominaterear, rise, lift - rise up; "The building rose before them"
That may enable you to be assisted, with your Request.
Looking forward to
Kind Regards....
Re: ABUBAKAR AWAN
02/11/2009 3:42 AM
what is your email ID .. I cannot attach a file to this .. send me your email ID at fareed_siddique@yahoo.com
Re: ABUBAKAR AWAN
11/04/2009 5:47 AM
Hello AbuBaker
What is the tower size and tower reactions. Please send me your email ID with all the details of tower so I can forward you teh exact design. Or Will you want a format design..? My email ID is fareed_siddique@yahoo.com
Mohammed Fareeduddin
B.E; M.E Civil Strl.
Member of:
ACI / AISC / TIA-EIA222 & ASCE
http://www.linkedin.com/in/mohammedfareeduddin
Andy Germany (2); BlueAussieBoy (1); DVader1000 (1); Fareed Siddique (1); guitarhunter (1); High Lander (1); Mohammed Fareeduddin (1); RF_guy (1); Sparkstation (2); wangito (1)
