Previous in Forum: inorganic metal coatings   Next in Forum: spong iron production cost
10 comments
corossion problems in a water packaging plant
05/26/2008 10:55 AM
i need a detailed explaination on modelling and analysis of corossion problems in a water packaging plant
Good Answers: 97
Re: corossion problems in a water packaging plant
05/27/2008 1:35 AM
dampness precipitating humidity or vice verse. poor ventilation
05/27/2008 3:17 AM
Add low pH and high conductivity to that.
05/27/2008 11:16 AM
what is your source of information as in websites
05/29/2008 5:04 AM
Websites? The chemistry course leading to an O-level examination grade in 1973 isn't knowingly featured in any website!
05/27/2008 5:07 AM
...and leaks.
05/27/2008 7:24 AM
...ambient temperature, coastal atmospheric salinity, atmospheric contaminants...
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
Re: corrosion problems in a water packaging plant
05/27/2008 8:51 AM
Also the more pure the water is the more aggressive it is. Water wishes to equalize (molecularly) with is surroundings. AS the 9's increase the more aggressive it is. 99.9% pure water is good . Then as you get to 99.99% and 99.9999% it gets much more aggressive. If it a purification process, you can get corrosion from that.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
05/27/2008 11:04 AM
pls i need a more detailed information on the modelling and analysis of corrosion problems in a water packaging plant
05/27/2008 12:31 PM
Hi austenite,
I think that your best option is to seek the services of a corrosion engineer. if you cannot find one, try a metallurgist who may know corrosion fairly well..................they should be able to explain the type(s) of corrosion, how and why it occurred and more importantly the steps to take to prevent further corrosion.
What you need to realise, is that before anyone can assist you with your corrosion problem many factors need to be considered - and really this cannot be successfully carried out using the internet.
05/29/2008 5:05 AM
It looks as though the original poster is in the best position to model and analyse this particular water packaging plant!
Register to Reply 10 comments
austenite (2); bwire (1); logix101 (1); MOBI (1); PWSlack (5)
