Previous in Forum: Level Indicator for Dry Lactose - Sanitary application   Next in Forum: Instrument
Ohm Signal Convert to 4 - 20mA or 1 - 5V Circuit Diagram
05/27/2008 1:30 PM
Hi all Expert,
I need a circuit diagram that convert 0ohm - 100M ohm to 4 - 20mA or 1 - 5v, with the zero and span adjust. Means when the input signal is around 0-500ohm and I can adjust the zero point to 4mA or 1V. And the the input signal is around 100M, then I can adjust the span point to 20mA or 5V. Hope that I could get some help from you all, Thanks
Good Answers: 38
Re: Ohm Signal Convert to 4 - 20mA or 1 - 5V Circuit Diagram
05/27/2008 10:53 PM
well i am not sure what application changes its Ohm value but your best bet would be to use some opamps to accomplish this.
05/27/2008 11:40 PM
There are a few instrument manufacturers that will modify std ohm-to-mA converters to specific requested ranges. Brands such as: APCS, MTL, Moore Industries, MANN, Intech and others. I know APCS will make virtually anything you would like that will output 4-20mA.
Good Answers: 12
05/28/2008 1:49 AM
I made one recently. Contact me on my mail ID as I am very poor on uploading pictures.
Subramanyam
05/28/2008 3:22 AM
hi
the best way is to buy resistance to current converter which available everywhere in the world with zero and span screw adjustment.
it is very easy to convert 4-20 ma to 1-5 volt by passing the current through 250 ohm resistance.
thanks for your time
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
05/28/2008 7:28 AM
Also try www.omega.com they have some of these and can set the devices up to your spects.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
Anonymous Poster (2); Epke (1); kvsubramanyam (1); logix101 (1)
