CARBON NANOTUBE:
Researchers studied multiwalled carbon nanotubes comprising anywhere
from two to 50 cylinders concentrically stacked with a common long axis.
Courtesy of the University of Edinburgh/MRC Center for Inflammation Research
<"http://www.sciam.com/article.cfm?id=carbon-nanotube-danger....May 20, 2008
Study Says Carbon Nanotubes as Dangerous as Asbestos
New research shows that long, needle-thin carbon nanotubes could lead to lung cancer
By Larry Greenemeier
Inhaling carbon nanotubes could be as harmful as breathing in
asbestos, and its use should be regulated lest it lead to the same cancer
and breathing problems that prompted a ban on the use of asbestos as
insulation in buildings, according a new study posted online today by Nature Nanotechnology.
During the study, led by the Queen's Medical Research Institute at the University of Edinburgh/MRC Center for Inflammation Research
(CIR) in Scotland, scientists observed that long, thin carbon nanotubes
look and behave like asbestos fibers, which have been shown to cause mesothelioma
, a deadly cancer of the membrane lining the body's internal organs (in
particular the lungs) that can take 30 to 40 years to appear following
exposure. Asbestos fibers are especially harmful, because they are
small enough to penetrate deep into the lungs yet too long for the
body's immune system to destroy.
The researchers reached
their conclusions after they exposed lab mice to needle-thin nanotubes:
The inside lining of the animals' body cavities became inflamed and
formed lesions.
Carbon nanotubes are generally made from
sheets of graphite no thicker than an atom—about a nanometer, or one
billionth of a meter wide—and formed into cylinders, with the diameter
varying from a few nanometers up to tens of nanometers. (They can be
hundreds or even thousands of nanometers long.) There is a greater
concern about "multiwalled" nanotubes consisting of several reinforced
cylinders, because they are able to retain their pointy shapes better
than thinner nanotubes.
Scientists have been noting the
similarities between carbon nanotubes and asbestos for the past few
years, says study co-author Andrew Maynard, chief science advisor for the Woodrow Wilson International Center for Scholars's Project on Emerging Nanotechnologies,
based in Washington, D.C. Maynard, who has been researching and warning
of the potential health and environmental risks of carbon nanotubes
since 2003, says that there has been no coordinated effort to date to
analyze the findings of carbon nanotube toxicity studies. He notes that
technology companies have not found that the risks of using carbon
nanotubes outweigh the benefits—they are excellent conductors of
electricity.
Carbon nanotubes can also be used to reinforce
polymers to create very strong plastics. University of Michigan at Ann
Arbor researchers are scaling the strength of nanosheets and a
nanoscale polymer resembling white glue. Visually, it looks like a
brick wall, in which clay nanosheet "bricks" are held together by
water-soluble polyvinyl alcohol "mortar". The result, according to the
researchers, is a composite plastic that is light and transparent but as strong as steel.
IBM has identified carbon nanotubes as important for studying
electrical and optical phenomena on the nanometer scale, and the
company has high hopes for the technology. Carbon nanotubes show
promise as building blocks for computer chips that are "smaller, faster
and lower power" than those made of silicon, Phaedon Avouris, an IBM
fellow and lead researcher on the company's carbon nanotube efforts,
wrote in the March 2007 issue of Physics World.
"One of the most exciting developments in carbon nanotube research is
the recent discovery that nanotubes can emit light," he added. "That
finding opens the door to circuits in which standard copper
interconnects are replaced by optical waveguides made from
nanotubes—allowing the possibility of fully integrated optoelectronic
circuits."
Nanotubes are likewise being developed for use in
new drugs, energy-efficient batteries, electronics and other products
under the assumption that they are no more dangerous than graphite. But
some scientists and environmentalists like Maynard caution that they
harbor hidden dangers. Compounding this concern is the prediction that
the market for carbon nanotubes will grow from $6 million in 2004 to
more than $1 billion by 2014, according to studies by a number of
firms, including the Freedonia Group.
A 2006 report from Lux Research projected that nanoscale technologies
will be used in $2.6 trillion worth of manufactured goods by the year
2014.
The Edinburgh CIR study, which will also appear in the
June issue of Nature Nanotechnology, was very specific, looking only at
nanotubes that emulated fiber behavior and their potential to cause a
certain type of cancer; other types of nanotubes could affect the body
differently—for better or worse, researchers say.
Maynard and
his colleagues focused their attention specifically on the hypothesis
that long, thin carbon nanotubes could have the same impact as
similarly shaped asbestos fibers. "If you get these things into the
lungs," he says, "they form scarlike tissue, and the body sees them
like a scaffolding, building new cells over them and thickening the
walls of the lungs."
The study is not intended to keep
nanotechnology from developing further but rather to flag potential
dangers of nanotubes in places at manufacturing and disposal sites, the
researchers wrote in their paper.
"There is an immediate need
to examine how carbon nanotubes are being used and see if there's any
chance that [people] are being exposed to dangerous materials," Maynard
says, adding that no one paid attention to the dangers of asbestos
until it was too late for a lot of people.....">
There we are, friends, something else to be concerned about.
It does appear that carbon nanotubes can and do penetrate most common "breathing mask filters", and may also penetrate the skin, and be absorbed via the eyes too.
I'm just hoping that carbon nanotubes don't become a greater problem than asbestos, which I used much of back in the 1950's through the 1970's.
At that time some warnings were sounded about the dangers of asbestos, but were generally ignored as being given by scaremongerers.
Kind Regards....
