Previous in Forum: What do you suggest to build a fire pit?   Next in Forum: Study Says Carbon Nanotubes as Dangerous as Asbestos
9 comments
ID kit on older snowflame stove 2100
05/27/2008 4:07 PM
I have a old snowflame 2100 stove 1993-4 I want to install a induced draft vent kit to keep help keep smoke out of the house I see a amaizablazE make a model 2100 that looks just like mine I spoke with a sales rep they tell me i cant use that kit because of the air adjustment he states my stove cannot be adjusted is this true. What will happen if I try it?
Re: ID kit on older snowflame stove 2100
05/28/2008 4:01 AM
What about increasing the height of the stack so as to induce more natural drafting?
06/01/2008 1:59 PM
Its direct vent through the wall.
05/28/2008 10:41 AM
Remember....induced draft was not designed when the stove was designed..........so of course they gave you that answer.
The lengthened stack will accomplish the same thing....but before you do that....check the total stack system above the firebox for soot/carbon build up...even small accumulations will have an impact...reducing velocity/volume transiting the vent.
The danger...minor...of the induced draft will create a hotter fire and may burn out the firebox if un lined. Reason? more fuel burn/higher heat/same radiation area to dissipate same.
MR. GUY
If you are looking for a positive answer..it's YUP......
06/01/2008 12:53 AM
Thanks for the reply
05/28/2008 1:24 PM
The 200 scfm air flow of the new Induced draft fan is double the 100 scfm of the forced draft fan needed for the snowflake 2100. Unfortunately, the Snowflake does not have a method of precisely adjusting the combustion air flow except properly selection of the combustion fan output. There is no "air flow adjustment screw" available on Snowflake stoves.
The $300 per IDF is also near double the cost of a 100 scfm IDF for the snowflame 2100.
The option to purchase a properly sized IDF for the snowflame 2100 is fully discussed on the cornstove website. The price of a properly sized 100 scfm IDF for the snowflame 2100 is approx $165 plus shipping. For details please visit www.groups.yahoo.com/group/cornstoves
Corn Stoves
06/01/2008 12:53 AM
06/01/2008 2:03 PM
Where can I buy this kit for my stove?
06/05/2008 3:51 AM
Local dealers for the induced draft fan kit (IDF) are listed on:
www.cornstoves.info and/or
www.cornstoves.com
www.groups.yahoo.com/group/cornplace
Corn Stoves
06/07/2008 12:28 AM
thanks
Anonymous Poster (5); Cornstoves (2); Mr. Guy (1); PWSlack (1)
