Previous in Forum: Pertol/gasoline with 2-stroke oil - disposal route   Next in Forum: models
32 comments
5kw DIESEL GENSET
05/28/2008 5:02 PM
Hi guys,
Jens here.
I got a question concerning a diesel engine.
I have installed a 5KW diesel genset (for power backup) in my shed (toolshed)
But I wanted it to run inside the shed, so I extended the exhaust
from the outlet of the muffler with just 16 inches of flexible automotive
exhaust pipe (1 1/2 inch dia.). And I ran it through the wall of the shed.
I made sure the engine would get enough fresh air from the outside by
providing the shed with forced air cooling (just a BIG fan).
Many years ago someone told me if one adds any lenght of exhaust to
a system like this, that it will raise the internal combustion temperature
and possibly damage the genset.
My question is this : IS THIS TRUE ?????
All the best
Jens
the electronics guy.
Pathfinder Tags: DIESEL GENSET
Good Answers: 230
Re: 5kw DIESEL GENSET
05/28/2008 7:05 PM
Hello Jens
You have not advised Make/Model of the genset, so my answer is a general one.
The short length (16 inches) of additional exhaust extension should not make much difference or damage the engine.
I presume that engine is water-cooled, if not water-cooled, then it is important it has sufficient ventilation, and your forced-air fan may be enough to do that job.
If you do have an air-cooled genset, you could place a minimum-maximum thermometer in the shed, and check it from time to time.
The Owner's Manual for the genset should advise the maximum air temperature for full output of the genset.
Some Makers give a temperature/output curve in the Owners Manual, with an absolute maximum for ambient air temperature.
Advise further if you are still concerned.
Kind Regards....
05/28/2008 7:21 PM
Hi Spark,
It's an aircooled generic model from China.
It's marketed by every Tom, Dick and Henry here in Canada.
It's called "Western Rugged"
I'll make sure it gets enough cool air.
I have an old gas genset, which I operated in that way and it never took any damage, but I just wanna make sure I don't wreck this new diesel.
I've had the gas genset since 1975, but it was only 2.7 KW just a little too small.
I know you are a ham, me also, maybe we can talk on 20m some day when the solar cycle gets back up again.
My callsign is VE3OOA
Thanks for your advise
all the best
Jens
in Canada
Good Answers: 97
05/29/2008 12:47 AM
Jens:
Let not yer heart be troubled, if yer not creating pressure by putting 6 or more elbows within a 2' span all is well.
For generic diesel extension pipe:
Make with shallow bends and increase pipe size 25%-50% of OEM, incline upwards with tip bent outward to keep rain/snow out. Run pipe up higher than shed roof, is okay if increase pipe size and suggest make with hard pipe not flex. Diesel does produce a soot, so you point the exhaust up and the soot will cool then drop to the ground within 200'.
06/02/2008 3:49 PM
In Guyana, what you've done is common practice. I've never personally experienced or heard of any such problem with such an installation. Since your engine is aircooled, what you could possibly try is some ducting from your big fan to the unit.
Sese
05/28/2008 11:34 PM
If unable to resolve the question with the manufacture use larger tubing as you extend the lenght so as not to provide back pressure. Allow for expansion in your piping.
Read page 12 on this site.
http://www.deep.org/reports/mechanicsman.pdf
05/30/2008 8:32 AM
Hi Dad with 5 boys,
It's a small world.
That PDF came from the college where I took my 3 year technology program in
instrumentation and robotics and automation.
What a surprise
All the best
Jens
05/29/2008 8:27 AM
Thanks guys for the advice
all the best
Jens
the electronics guy
Good Answers: 12
05/30/2008 2:44 AM
Now that we know it is possible, you might want to provide insulation around the exhaust pipe where it goes through the wall or ceiling of your shed. It would be embarrasing to set the bloody thing on fire... especially if you had no hotdogs or marshmallows.
Bill
05/30/2008 8:24 AM
Hey thanks for mentioning the need to insulate the wood from the hot exhaust,
I did have enough foresight to do that.
I'm more concerned about my old gas genset leaking on the floor and setting the shed on fire, that's why I built it far enough away from the house so if it should happen, I'd still have the house.
all the best
Jens
05/30/2008 3:48 AM
Dear Jens,
I am using Diesel gensets of 6KVA to 160 kva capacity
and are running them sometimes for even 24 hrs continuos
basis ,each of them have extensions of 6ft(1.8 metre) to
16 ft (4.8 metre) .We have not had any problems even at
47 degree celcius ambient tempratures.My own experiance
is over hundred thousand hrs. As you have provided
forced ventillation I can say that you should not
have any problem.
Regards
Kishore K.Gupta
New Delhi INDIA
05/30/2008 8:52 AM
Thanks Kishore for telling me, now I won't worry about overheating.
We only get temperatures as high as maybe 35 Celsius and that rare for a summer in
northern Ontario Canada, but we get real cold in the winter sometimes -45.
And a diesel is hard to start in that cold temperature.
Long time ago I had a Case430 tractor and to start it in the winter one would have to
"rub on it" and pray over it. "I'm only joking", but it was very hard to start in the winter, we ran a small hobby farm at the time.
Take care Jens
Good Answers: 123
05/30/2008 9:08 AM
If the fan you are using to bring fresh air in is of sufficient volume it should force air to escape out from any leakage as pipes pass through the walls. A CO2 monitor would be a good idea as well. Not too expensive. An older Detroit Diesel that we had came equipped with a factory "cold start" option. In addition to the in block electric heater, it had a propane assist for starting in the extreme cold. The system could spray a small amount of propane while starting if temperatures demanded it. By some good luck we never had any temperatures hear in Fort Lauderdale that required it. If your diesel is hard to start in the cold weather, I would suggest trying to bring some heat to your shed.
Bob
05/30/2008 6:58 AM
I like their answer every time I hear it. They don't have a understanding of the mechanics of the exhaust system. The purpose if the system is to mover the smoke and the noise away from the engine. The old time applications belched out so much unburned fuel and at low temps that it would clog the exhaust system. The other extreme was to allow the exhaust to exit the head and not to worry about the noise and smoke. If the engine is left uncovered and in rain the water could enter the ports and destroy the engine. The exhaust on the trail bike is great in technology for research. You can make it long enough to exit the the confined area. The real way to optimize the system is to take the pulse rate of the exhaust (RPM). Them the speed of sound. You them tune the exhaust so the shock wave creates a pulse at the valve port at the cylinder head. The term is called (Tuned Exhaust) Every racer uses this system to optimize the performance. NASCAR, and NHRA. The thing you are looking for is a pipe long enough to remove the exhaust and noise. A pipe to long or to big becomes cool and fill with shoot.
Good Answers: 97
05/31/2008 1:05 AM
NASCAR, and NHRA.
Using diesel these days and for performance applications too...
Good Answers: 123
06/02/2008 10:50 AM
To that list add the American Le Mans Series.
Bob
05/30/2008 8:04 AM
Yes slightly more work, but insignificant in your case, sounds like you did it right.
Just be sure to provide sufficient air for cooling and injestion.
Good Answers: 123
05/30/2008 8:33 AM
There is a company, called Markal, that sells crayons that melt at specific temperatures. I bought mine from Grainger years ago. Find the max recommended temperature from the gen set manufacturer. Rub the crayon at, or just below the max temp on the crankcase or some other assessable area. If the crayon temp is reached, it will melt, and appear shiny. All of the suggestions on the exhaust so far have been good, but try to avoid PVC pipe as it will not do well in the cold environment.
Bob
05/30/2008 8:36 AM
Jens,
I am certain that there is a specific exhaust extension kit for your particular set. They have them for RV's and home use sets. It usually comes with the proper exhaust manifold gaskit and would probably give you better tuning and performance. They are redily available on the internet, and are fairly inexpensive. Also you should insulate at least around your exit point to insure both fire safety and the threat of re-entering carbon monoxide.
Cheers.
05/30/2008 8:57 AM
Thanks guys for your help, it's much appreciated.
Jens
05/30/2008 9:32 AM
Jens,
I think I have the same generic Chinese generator set that you have. I installed it in my garage and extended the exhaust through the wall similar to what you have done. I also used a section of flex pipe to isolate vibration. Just to be safe, I used all 1.5" ID pipe, slightly larger than the size of the muffler outlet, to reduce back-pressure. There are 4 elbows in the system. The total extension is over 10', with no noticeable problems. I did make sure to install a sleeve in the wall and pack the area between the pipe and sleeve with non-flammable insulation so the wall doesn't catch fire. I also wrapped the entire pipe with fiberglass header wrap.
I also welded a pipe nipple to the muffler outlet and put a union right there, so I can easily disconnect the exhaust extension and remove the generator if I need it portable.
05/30/2008 11:04 AM
Hi Greasy,
It looks like we have the same kind'o genset.
But I didn't have to do any welding. The flexpipe 1 1/2 inch dia. fit snugly over the small black pipe sticking out of the muffler. And I just used an automotive mufflerclamp to fasten it.
How many hours of operarion have you got so far ????
Have you looked at the waveform of the 120/240 ???
Very lousy immitation of a sinewave. I expected it to be much better.
I would NOT run my computer on it, with out a good 60 hz filter.
Laptop is OK I think, but not desktop.
I noticed the multiple step waveform and I was surprised that it wasn't smoother
than it showed.
I'm kind'o disappointed, but it'll have to do. It will however run my whole house, but only with the hotwater tank turned off. That's OK with me.
All the best
Jens
05/30/2008 2:50 PM
Jens,
My outlet pipe was a little small to clamp the 1.5 inch directly to it. Plus, I just like to find welding projects, and I thought it would leak less than a muffler clamp. I brazed the 2' flex pipe to a threaded nipple and used schedule 40 galvanized pipe from there. To keep the rain and bugs out, I capped it off with a tractor exhaust flapper too.
I really don't have many hours on it because it is a standby generator. Maybe 15 hours total. I added a digital hour meter even though it sits most of the time. I have also been able to run the whole house including the oil furnace, the fridge, and the well pump.
Thanks for the warning on the waveform--I was not aware of that. I will be careful what electronics I am using when under generator power. I figured there would be some cons with this machine, but for the price, you can't beat it.
05/30/2008 4:25 PM
Hi Greasy,
I think I'll also put a flapper on the end of the pipe.
I told you that I can't run the house with the hot water tank ON.
But I found a way to do that and if you are interested I'll let you how.
But if you are on natural gas you're OK without the modification.
Where did you get an hour-meter ???
I live on a small farm here in northern Ontario Canada
and I had 3 black outs this month alone.
One was 10 hours. (a drunk driver knocked out a pole and transformer).
I didn't buy the genset just for the toy. We really need it up here.
Last summer we were out (if I remember correctly a full day).
And I won't ever forget the blackout of 2003 (I think it was 4 days).
I did have the old gas genset then and we didn't loose any food.
But we live in the country (in the bush) and we are not as important
as all the folks in the city. So they get first help.
all the best
Jens
05/30/2008 5:49 PM
Jens,
The hour meter came from my local NAPA auto parts store. They have a master catalog of parts for all sorts of things. Not the flapper, though. That came off the shelf at Tractor Supply Co.
I was expecting to lose power more often where I live, but "out in the woods/bush/country" is only 15 minutes from civilization near me.
With one major ice storm, hurricane, or blizzard it will pay for itself. They are rare for us, but only time will tell when the next one comes. And I'll be ready.
Take care
05/30/2008 6:21 PM
Thanks greasy,
We have a NAPA store nearby.
I'll get one
Thanks a million
Jens
Good Answers: 123
06/02/2008 10:52 AM
How did you solve the hot water heater problem?
Bob
06/02/2008 7:13 PM
Hi Bob,
Very simple :
We don't have the kids at home any more. We are kind'o retired.
So we don't need 1 or even 2 hour recovery on our hot water.
We only take 1 shower/person/day and we only wash clothes when we have enough for a full load.
So I simply rewired the tank and the panel to run at 750W instead of 3000W.
I don't care if it takes even all day to recover the heat in the tank.
Now it takes 4 times longer than with 3000W.
3000 divided by 750 = 4.
You can even lower it to 375W if you really want to sqeeze it.
But if you have kids (especially girls, they take a lot of showers) forget it
(you'll run out of hot water)
So now I can run almost everything. Hot water tank, well pump, furnace,
sump pump and stove, light (CFL only) and 1 window air cond.
(but the wife can't bake though, that'll have to wait till the grid comes back on).
and no clothes dryer. (dry it on a line outside or inside).
all the best
Jens
06/02/2008 7:44 PM
That includes fridge and freezer, I forgot to mention.
I'm sitting in front of the computer, I can't think of everything, sorry I'm past 65.
And I don't run my PC on the genset. Very lousy waveform coming out of those type of generators.
Jens
08/22/2008 5:03 AM
Main thing is that you do not put too much back pressure onto the engine ... which you will not with an open ended 1.5" x 16" tube connected onto the end of the existing. You should not have any problems.
08/22/2008 8:47 AM
Hi Thanks for your advice,
I didn't think I had too much restriction on my exhaust either, thanks.
regards
Jens
Good Answers: 25
10/15/2008 11:31 AM
Hello Jens, TMF here.
I just happened upon your 5kw diesel genset thread. Here in sunny Florida, many of the Orange groves are irrigated with diesel powered well pumps. Many of these are housed in inclosed sheds. They all either leave the large doors open for ventalation or have very large louver panels mounted both near the bottom and tops of the walls. This permits the engine to pull cooler air in from the bottom for combustion and have the hot air exhaust naturally at a higher level. I have noticed that the exhaust pipes can be lengthy, depending on how the engines are arranged within the building, but the exhaust pipes are always larger than one might think necessary and are not reduced after the exhaust vacates the engine.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
10/15/2008 4:05 PM
THANKS TMF
REGARDS
JENS
Register to Reply 32 comments
Anonymous Poster (6); bob c (4); bwire (2); dadw5boys (1); Jens (12); Sciesis2 (1); sese_norville (1); Sparkstation (1); Toomuchfun (1)
