A few shafts (gear pinion) has broken at the end of coupling at keyway. material is OK. It is carburized, hardened and tempered. If it had failed at key root, cause is obvious. But surprisingly the failure is from tip of the key (half round key and keyway). The failyre has started tangentially from the tip and not touched the keyway crossection. On broken piece the shape of K/Way is not visible at all. Any hypothesis on the cause of failure will be welcome. Google search do not show any failure mode from keyway tip. all are from root (notch fatique). failure is about after 1000 hrs of operation.
