Previous in Forum: MCB curves   Next in Forum: phase shift
Selection of Generator
05/30/2008 6:15 AM
I am in the process of selecting a Diesel generator for running plastic porcessing machineries. There has been contradicting suggestions. Kindly give me your suggestions.
-Devarajan
Re: Selection of Generator
05/30/2008 6:55 AM
Please describe the contradicting suggestions.
05/31/2008 12:00 AM
DC load to be multiplied by 4 or 2?
generator to be selected for maximum load or the practical 60% load?
Total KW to be the load selection criteria?
Good Answers: 19
05/31/2008 12:43 AM
DG set selection is based on
1) Load to be connected
2) Types of load
3) Method of starting of drives
4) Sequence of starting
May be we can help you in selection, provided you furnish all the particulars mentioned above.
Ramesh,Freelance Electrical/automation Consultant
05/31/2008 11:57 PM
Total DC load is 225.15KW
Total AC load is 722.7Kw
Total Heater load is 314.09Kw (single phase)
DOL starters only for motors of utilities below 5HP
AC variable frequency drives for plant drives irrespective of HP
No Sudden ramping up/down for any drives other than Utilities
Plants start up gradual and no sudden loads.
-devarajan
Good Answers: 19
06/01/2008 2:15 AM
1) How are you converting AC supply to DC supply-Method ?
2) Can you not distribute the single phase Heater load equally to all the three phase ?
3) The loads should be distributed to all the phases.You can not have 50 % of the load as single phase.
06/01/2008 2:47 AM
the drives are SCR controlled supplied by ABB and Siemens.
The heater loads are distributed on to three phases, but when the Die heads are changed there may be minor imbalances
Good Answers: 19
06/01/2008 7:44 AM
Can you explain and give more details of DC Loads.
Register to Reply 7 comments
devarajan (3); PWSlack (1); ramvinod (3)
