Previous in Forum: Determining Impact Penetration & Stationary Object Movement   Next in Forum: How Do I Keep from Burning Up My House After I Heat Shingles with Blowtorch?
Optics question, light refraction reduction
06/02/2008 1:55 PM
Optics question. What is a recommended treatment/finish for internal surfaces of lens holders to reduce/eliminate light refraction? Application notes, Lens holder is aluminum and attached to an OEM camera body.
Good Answers: 918
Re: Optics question, light refraction reduction
06/02/2008 2:01 PM
Check with companies that sell parts for telescope building. This is a common thing for builders and the solutions run from simple to complex depending on how much performance you want.
06/02/2008 11:22 PM
Are you wanting to control the "reflected" light coming off of the aluminum surface lens support?
This is it... so live it up!
Good Answers: 70
06/02/2008 11:31 PM
One of the easiest solutions is to cut a fine thread (1 mm pitch or less) with a minor diameter equal to the ID of the fixture. The steeper the thread angle the better. When anodized the threads will act as a light trap.
06/03/2008 1:02 AM
You almost answered the question! Specify unpolished Black Anodize!
Good Answers: 109
06/03/2008 2:54 AM
Hi,
black anodised is not really good as this is reflecting in the infrared.
I got a black paint from a shop that is supplying amateur telescope builders, this paint has an ordinary use for school blackboards. If mixed with fine particles the black will be "more black".
There is also the ultra-black paint used today on cars instruments, but the primer is near 30€/kg and the paint near 130€/kg.
Make the edges of the lens holder very sharp without deburring! This will yield much less straylight.
RHABE
Anonymous Hero (1); dkwarner (1); johnfotl (1); RHABE (1); Skeeter (1)
You might be interested in: Light Emitting Diodes (LED), Lens Holders
