Previous in Forum: dripleg size   Next in Forum: Refrigeration
Engineering Fields - Piping Design Engineering - New Member
material selection
06/03/2008 2:01 AM
how to chose material selection according to the process fluid please any one can give ma answer.
Nimmagadda ramakrishna
Re: material selection
06/03/2008 2:52 AM
06/03/2008 6:36 AM
is not so easy... a corrosion chart can give you some advise on what can u expect.. but you need to be sure that your conditions are the same of the corrosion chart..
Also there are other factors to be considered.. the minimum temperature.. external corrosion (atmospheric corrosion).. erosion, erosion-corrosion due to high velocitiy gas..
so.. the corrosion chat or corrosion database or isocorrosion curves gives you a first impression.. then you've to evaluate all the rest...
what's your fluid?
S.
Good Answers: 101
06/04/2008 1:56 AM
Process temperature, pressure, material compatibility with process fluid etc.
Register to Reply 3 comments
DVader1000 (1); PWSlack (1); strider6 (1)
