Previous in Forum: Fail Lamp Detection.   Next in Forum: Power Transformer
16 comments
Power resistor?
06/03/2008 9:10 AM
Well, it seems the tables have turned. After having posted more than my fair share of foolish answers I now have to ask a foolish question.
I have an application where I must tie a 2W resistor to an 120V AC hot line. So...what's the distinction for a "power resistor" as compared to a normal one? And of the types of "power resistor" am I better off using metal oxide, metal film, etc?
I can add that I'm limited in body size to around a 1/2" (13mm) length.
Re: Power resistor?
06/03/2008 9:11 AM
I should have also added the part must be through hole. And it's for a commercial product where UL certification is a must.
Re: Power resistor?
06/03/2008 9:41 AM
Take care..not only do you have to make sure the resistor can handle the watts...it must be rated to handle the voltage too.
I wouldn't worry too much about the type...that only really comes into play if you want good temperature/noise/stability characteristics.
I expect you're only worried about wattage, voltage, price and availability. (Usual rules apply ..e.g if it does everything you want...they aren't available. At KrisDel enterprises everything which is out of stock is half price)
Good Answers: 27
Re: Power resistor?
06/03/2008 9:57 AM
A "power" resistor is simply one that is designed to conduct high current in a relatively small resistor package. Typically, power resistors range from about 5W to kilowatts. Low power resistors are designed to withstand the heat generated by the I²R (power) loss but higher power resistors generally require auxiliary internal or external cooling by air, water, or other medium to dissipate the heat.
Suggest Googling "power resistor" for manufacturers, suppliers, and application information to help select the type that is best for your application.
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Power resistor?
06/03/2008 10:05 AM
You have forgotten to point out its (resistor) nominal in Ohm. It makes a HUGE sense for resistor's dimensions.
Re: Power resistor?
06/03/2008 10:25 AM
Iv'e never noticed this in relatively low powered resistors... e.g 2W and less in the range of a few ohms to a few meg ohms.
Re: Power resistor?
06/03/2008 10:52 AM
Hi Del, hope you enjoy your time spent in the garden.
I'm supposing that resistor nominal here from some 7.2 kOhm to dozens of MOhm make sense for resistor size restricted in dimension within 13 mm.
Though I can be wrong. In any case this resistor can't be Ohm it should be more than some 6.8 kOhm.
regards, caramba
Re: Power resistor?
06/03/2008 10:54 AM
(Your cute Avatar is missing... )
Re: Power resistor?
06/03/2008 11:11 AM
I'm just working along mine rebrandering. I intended to place here something like chopsticks as next symbol of SE Asia that I adore. But only guessing your feasible reaction, I've decided do not change kittycat association. Just only make it less gender controversial to shun any "broken heart" issues.
Re: Power resistor?
06/03/2008 12:10 PM
LOL
Good Answers: 40
Re: Power resistor?
06/03/2008 11:36 AM
As far as type, goes, I have found the "wire wound " resistors, as the most reliable, and slightly more accurate then the ones you mentioned.
Good Answers: 19
Re: Power resistor?
06/04/2008 4:33 AM
Hear, hear! Unless they are run well beyond their nominal ratings, wire wound resistors are extremely reliable, and don't drift. At 60 Hz, their relatively high inductance can be safely ignored.
Re: Power resistor?
06/04/2008 8:25 AM
techno,
I agree with you regarding wire wound resistors being the most reliable. However, they may not be suitable in certain instances where the introduction of inductance can be a problem.
Good Answers: 40
Re: Power resistor?
06/04/2008 10:09 AM
Agreed, however he is simply using it on an Input power line at 60HZ. There should be no problems. I believe it is where they are used the most.
Good Answers: 38
Re: Power resistor?
06/04/2008 12:09 AM
Lots of Power resistors use ceramic materials to dissipate the heat.
you could use normal Resistors but then you would have to put a bundle of them parallel to get the required power value.
As far as i know, if you use uncommon values outside E24 series at higher power ratings than these power resistors are harder to come by.
Re: Power resistor?
06/04/2008 10:32 PM
"I now have to ask a foolish question."
What is the maximum current the resistor is expected to handle?
Re: Power resistor?
06/05/2008 11:09 PM
More information required.
As Sterling Stan has requested, what is the current draw.
Also it would be good to understand what other features are close by and what is the expected duty cycle.
We use Nichrome wire and make our own sense resistors for circuit board mounting, or even have a local spring manufacturer wind them for us. You may be able to find a gauge of wire that provides your exact resistace in 13mm length or close enough to have a pinched standoff with the wire a few mm from the board surface.
You still have a significant challenge with "through hole" application of a 2 Watt resistor. Some of the HEAT will be conducted through the leads to the board connection points.
My observations are that over time the solder will "change" and become extremely brittle and you will get cold joints. (Unless you have good heatsinking ground planes and such.) That's why you need to understand the duty cycle and other features on the board.
You may get UL approval for each of the components but in the combined system condition there still could be failure.
Reply to Forum Thread 16 comments
Anonymous Poster (1); Bluestone (1); bubbapebi (1); caramba (3); Epke (1); Just an Engineer (1); Stirling Stan (1); techno (2); user-deleted-1105 (4)
