Previous in Forum: Pipe Rack Distances - Are There Limitations?   Next in Forum: Design Standards for Plastic Enclosures for Servo Motors
Air Motor and Compressor calculations
06/05/2008 2:37 AM
Hi Folks,
Can someone point me to calulators or formulas for calculating torque out
vs air pressure in for vane type pumps or compressors and motors ?
Trying to make sense of an energy problem, and the engineering class was too long ago.
Thanks
rcb
Testing =Testing -Testing -- We create our society each time we interact with another person. What kind of society did you create today. RCB
Pathfinder Tags: calculation Pressure torque
Re: Air Motor and Compressor calculations
06/05/2008 3:43 AM
Shaft power (without losses) = pressure change x volumetric flowrate
Does that help?
Good Answers: 137
06/05/2008 7:19 AM
And power = torque x speed.
06/05/2008 8:54 AM
Yep!
06/05/2008 11:46 PM
Where do we get the torque - must be a calculation somewhere round here.??! :)
06/05/2008 11:45 PM
Where do we get the conversion from Pressure to torque -
Different size air motors surely have different torque curves etc.
How to figure ? Or must we first find a motor and look up the manufactures specs.??
rcb
Good Answers: 137
06/06/2008 4:33 AM
Hello rcbondsr
You know discharge absolute pressure P2. If you know inlet flow q you can calculate compressor input (shaft) power W. For compressible flow it's a bit more complicated than PWSlack's post #1. P1 is inlet absolute pressure. n is polytropic exponent, usually 0.23.
If you don't know inlet flow direct, you can get it from speed, swept volume per rev, and volumetric efficiency. VE I'd guess 90 - 95% for sliding vane type, but somebody may know better.
Dividing power by compressor speed gives torque.
Need to do it all in consistent units, I prefer SI. Note speed needs to be in rads/sec.
Cheers.......Codey
Register to Reply 6 comments
Codemaster (2); PWSlack (2); rcbondsr (2)
