Previous in Forum: Transformer Unbalance - Open CKT Voltages   Next in Forum: Steel Skywire - Short Circuit Capacity
Location: Located in Qatar, working as a Head of Engineering
Why Use a Sheath Voltage Limiter in Single-Point Bonding?
06/05/2008 9:44 AM
Why should we use "Sheath Voltage Limiters" in Single Point / Cross Bonded type of link boxes. What is the purpose?
Value has a value, Only if its value is valued...
Re: What is the purpose of using Sheath Voltage Limiter in Single point bonding?
06/05/2008 2:36 PM
A sheath voltage limiter (SVL) is the common name which is used to describe a metal oxide
surge arrestor which is used to protect any part of the sheath insulation from transient over
voltages.
