Previous in Forum: Wanted: Boeing Riveting Specifications   Next in Forum: Converting ft/min into mm - Column of Water
Sharpening Ceramic Parts
06/05/2008 1:47 PM
what is the procedure to sharp the ceramic parts?
Re: Sharpening Ceramic Parts
06/05/2008 10:48 PM
Not sure on what specific "parts" you're referring too. But how we in the culinary industry for our knives would do it is that you had to use stones and "steels" with diamond in them with different grit to get the desired sharpness. To my knowledge diamond is the only thing that can cut ceramic. Though first the ceramic must be hardened by a tempering process using high heat to harden the piece otherwise it will be brittle and easily shatter. This is just one side of it, there could be other ways and processes I'm unaware of, but this is from my experience.
