Previous in Forum: Hydrogenation   Next in Forum: welding of cast iron to steel
membrane software
06/08/2008 1:39 AM
Good Day. I have membrane process and i would like to have software that can enable me to calculate the composition of permeate and flow rate and non- permeate and its flow rate. Does any body have this kind of software. Thanks
Good Answers: 101
Re: membrane software
06/08/2008 11:39 PM
You can download a free membrane software at the following website:
http://www.membranes.com/index.php?pagename=imsdesign
It's by Hydranautics, so note that it only works for their membranes, unless your membranes are compatible.
06/09/2008 4:17 AM
my membrane is not designed for hydranduatic applications, it is for organic applications and i need software to make simulation much easier . notabally, i did not find membrane process in Hysys and Aspen. Thanks
06/09/2008 3:35 AM
Reverse Osmosis, perhaps?
All manufacturers have design packages that can do this stuff.
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
06/09/2008 9:18 AM
Try Pureflow in Graham N.C. USA. That is the RO system we are using. They will help any way they can.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
Register to Reply 4 comments
Che_455 (1); DVader1000 (1); logix101 (1); PWSlack (1)
