Previous in Forum: Engineer   Next in Forum: Air Compressor Cfm
zetex
06/08/2008 3:51 AM
Hi
somebody kindly can tell me about the ZETEX . in the drawings of equipments this material has been used for sealing between flanges.
thanks
Pathfinder Tags: zetex sealing material
Re: zetex
06/08/2008 10:27 AM
The only Zetex I know is based up in Oldham and manufacturers the most wonderful transistors ever.
Used to be Ferranti until 1980s.
Don't suppose that helps much eh?
Re: zetex
06/09/2008 9:10 AM
Zetex is a fabric material woven from fine silica 'fibres' and when used as gasket material it is ideal for high temperature applications up to about 1100 deg Centigrade.
Regards, Pete.
Having a farm is great provided you don't have to depend on it for a living.
Re: zetex
06/09/2008 9:22 AM
Progress -
The likely product is for a high temperature textile. ZETEX is a registered trademark of Newtex Industries in Victor, NY. A search of TESS, the USPTO database produces the following table below (if the Paste works ok). There are other ZETEX trademarks. To have a look, click here and type in ZETEX in the search term.
Hope this helps.
jhammond
________________________________
www.patent-innovations.com
Note - website under reconstruction due to server crash ~6/3/08
Word Mark
ZETEX
Goods and Services
IC 009. US 026 039. G & S: articles of clothing made from non-flammable fabric; namely, fire entry suits, and insulating and fire retardant suits, coats, sleeves, pants, leggings, spats, hoods, helmets, aprons, gloves, mitts and finger cots. FIRST USE: 19790219. FIRST USE IN COMMERCE: 19790219
IC 022. US 007. G & S: ropes of non-flammable material. FIRST USE: 19790219. FIRST USE IN COMMERCE: 19790219
IC 024. US 042. G & S: non-flammable textile material not of asbestos for use in manufacture of insulation, sealants, padding, tape, tubing, and fabricated products for welding, fire, cold and electrical insulation and stress relief and chemical barriers. FIRST USE: 19790219. FIRST USE IN COMMERCE: 19790219
Mark Drawing Code
(1) TYPED DRAWING
Serial Number
74199599
Filing Date
August 30, 1991
Current Filing Basis
1A
Original Filing Basis
1A
Published for Opposition
August 18, 1992
Registration Number
1730789
Registration Date
November 10, 1992
Owner
(REGISTRANT) NEWTEX INDUSTRIES, INC. CORPORATION NEW YORK 8050 Victor-Mendon Rd. Victor NEW YORK 14564
Attorney of Record
NEAL L. SLIFKIN
Type of Mark
TRADEMARK
Register
PRINCIPAL
Affidavit Text
SECT 15. SECT 8 (6-YR). SECTION 8(10-YR) 20030607.
Renewal
1ST RENEWAL 20030607
Live/Dead Indicator
LIVE
My aspect ratio is 2.28.
Re: zetex
06/09/2008 10:21 AM
Hello,
Zetex is an E glass fabric coated coated or not . You will find the right Zetex for your need at www.newtex.com .
Rgds,
Murilo Signorelli(msignor@terra.com.br )
Brazil
Re: zetex
06/10/2008 7:11 AM
Hi, My friend is mfg. such material for use as gaskets. I am from Mumbai, India if you need this material then please let me know the qutty and other specs then I can ask him to quote you.
Regards,
Suresh Sharma.
Anonymous Poster (2); BigPete (1); Electroman (1); jhammond (1)
You might be interested in: Pipe Flanges, Sealing Machines, Timing Pulley Flanges
