I am in need of a "slip ring" for use at 150KV. I have a 4" conductor that I would like to be able to rotate on an axis (no more than 60") and thought a slip ring would do the trick. I do not need ground isolation, as the whole assembly will be at line voltage, but Partial Discharge is the upmost concern becuase we are also using this system for PD test of insulators. The current is low (<500mA) and the whole assembly will be on the line conductor isolated from ground using the insulators under test.
My question is: can anyone recommend a low current slip ring that I could use? Experimentation with several designs is not really feasable. Thanks, Mark
