Previous in Forum: HT voltage   Next in Forum: Star Point Grounding of Neutral -220kV Primary Side
India - Member - New Member
Derating Current
06/11/2008 11:49 PM
what is the purpose of derating current?is it necessary to consider while calculation
Knowledge Sharing
Re: derating current
06/12/2008 3:36 AM
In what context?
06/12/2008 4:20 AM
for the cable
Knowledge Sharing
06/12/2008 4:49 AM
A cable's ability to dissipate heat is limited by its construction and the environment in which it finds itself. Derating is necessary to ensure the cable survives without damage while the circuit protective device operates. Otherwise there is a risk of fire.
BS7671 ("the Wiring Regulations") gives algorithms whereby any cable's derating may be assessed.
Re: Derating Current--no escaping it
06/12/2008 11:41 PM
Derating prevents the powered circuit's ratings (the point of destructive stress on the most vulnerable element) from being approached closely or exceeded over the realistic expected range of operating conditions, both inherent and environmental. It is necessary...both technically and from a warranty/liability perspective.
Register to Reply 4 comments
Anonymous Poster (1); ganeshakce-electrical (1); PWSlack (2)
