Previous in Forum: Structural Steel   Next in Forum: Steel Ships - Emergency Repairs Underwater
Factory Acceptance Test for Diesel Generators
06/12/2008 12:50 PM
what are the required factory Acceptance Test (FAT) required for a 1.8MW Diesel generator
Good Answers: 39
Re: Factory Acceptance Test for Diesel Generators
06/12/2008 11:09 PM
That is usually determined by the buyer in the purchase contract or perhaps even in the (RFQ) Request for Quotation.
Elnav
06/13/2008 11:09 AM
The ASME performance tests standard for combustion turbine generators is PTC 22, for combine cycle plants it is PTC 46.
I am sure there is one for diesel engines but I just cannot lay my hands on it right now.
06/18/2008 9:33 AM
Quite. Go back to the purchase requirements document. It may be stated in there. If it isn't then it's going to be a rough ride.
05/01/2015 12:05 PM
Dear Mr.morakiniyo,
Pl.refer the details given below which will be very much useful to you as per your expectations. This is given in the ELECTRICAL GENERATING SYSTEMS ASSOCIATION as given below. There are seceral details and you click on the blue text and it will open and you can down load the same and save.
http://www.egsa.org/Publications/Standards/DownloadStandards.aspx
Download All Final Standards in a Zip File
Download a zipped file of the entire set of EGSA standards in a compressed file (1.5MB)
100 Series Standards
Under the purview of the Power Generation Components Subcommittee.
Category Title Size Description
Batteries
EGSA 100B-1997: Performance Standard for Engine Cranking Batteries Used with Engine Generator Sets
36.00 KB Contains requirements for rating, classifying, applying, installing and maintaining engine cranking batteries.
Battery Chargers
EGSA 100C-1997: Performance Standard for Battery Chargers for Engine Starting Batteries and Control Batteries (Constant Potential Static Type)
31.00 KB Contains requirements for voltage and temperature limits, application and accessories for charging engine cranking batteries.
Breakers, Thermostats, and Thermistors
EGSA 100D-1992: Performance Standard for Generator Overcurrent Protection, 600 Volts and Below
34.00 KB Contains performance specifications for circuit breakers, field breakers, thermostats, thermistors and other temperature detectors.
Diesel Fuel System with Above Ground Tanks
EGSA 100T-1995: Performance Standard for Diesel Fuel Systems for Engine Generator Sets with Above Ground Steel Tanks
31.00 KB Contains application and performance requirements for diesel fuel supply systems with above ground steel tanks for diesel engine driven generator sets.
Engine Protection Systems
EGSA 100F-1992: Performance Standard for Engine Protection Systems
44.50 KB Contains performance specifications for engine control systems including temperature, level, pressure and speed sensing.
Governors
EGSA 100E-1992: Performance Standard for Governors on Engine Generator Sets
47.50 KB Contains classifications, performance requirements and optional accessories for generator set engine governors.
Instrumentation, Control and Auxillary Equipment
EGSA 100G-1992: Performance Standard for Generator Set Instrumentation, Control and Auxiliary Equipment
52.50 KB Contains requirements for generator set engine starting controls, instrumentation and auxiliary equipment.
Multiple Genset Control Systems
EGSA 100M-1992: Performance Standard for Multiple Engine Generator Set Control Systems
34.00 KB Contains performance requirements for manual, automatic fixed sequence and random access generator set paralleling systems.
Peak Shaving
EGSA 100P-1995: Performance Standard for Peak Shaving Controls
26.00 KB Contains requirements for parallel operation and load transfer peak load reduction controls.
Transfer Switches
EGSA 100S-1996: Performance Standard for Transfer Switches for Use with Engine Generator Sets
43.50 KB Contains classifications, applications and performance requirements for transfer switches for emergency and standby transfer switches.
Voltage Regulators
EGSA 100R-1992: Performance Standard for Voltage Regulators Used on Electric Generators
37.50 KB Contains application and performance requirements for generator voltage regulators.
101 Series Standards
Under the purview of the Power Generation Systems Subcommittee.
Engine Driven Generator Sets
EGSA 101P-1995: Performance Standard for Engine Driven Generator Sets
366.50 KB Contains classifications of use, prime mover configuration and ratings, and performance requirements for complete generator sets.
Glossary
EGSA 101G-1998: Glossary of Electrical and Mechanical Terminology and Definitions
136.00 KB Contains definitions of terms specific to the on-site power industry.
Guideline Specification
EGSA 101S-2005: Guideline Specification for Engine Driven Generator Sets, Emergency or Standby
108.00 KB Guideline specification in blank form for preparing specifications for emergency or standby generator sets.
Other Standards
Developed as needed.
Genset Test Methods
EGSA 107T-1999: Performance Standard for Generator Test Methods
15.40 MB
Now available for download. This is a large download. Please be patient. This standard provides a variety of methods for measuring and determining characteristics for electric generators and generator sets.
List of Codes and Standards Adopted by U.S. States
EGSA 109C-1994: Code Listing: Safety Codes Required by States and Major Cities
71.50 KB A listing of national and international codes and standards adopted by U.S. states and selected major cities.
Seismic and Wind Certification for IBC Compliance
EGSA 200W-2009: Recommended Practice For Seismic and Wind Certification for Compliance to the International Building Code (IBC)
68.00 KB Full Title: Recommended Practice For Seismic and Wind Certification for Compliance to the International Building Code (IBC) For Electrical Generating Systems and Various Critical Components for Building Design Categories C, D, E or F per Chapter 13 of ASC
Silencer Rating Guide
EGSA 201S-2014 Guide for Rating Generator Exhaust Silencers
477.11 KB The purpose of this guide is to provide a uniform noise reduction rating system for exhaust silencers used on reciprocating internal combustion engines that are utilized for the purpose of generating electrical power.
DHAYANANDHAN.S
Register to Reply 4 comments
Anonymous Poster (1); dhayanandhan (1); elnav (1); PWSlack (1)
You might be interested in: Light Guides, Fiber Optic Light Guides, Monochromators
