Previous in Forum: Steel Ships - Emergency Repairs Underwater   Next in Forum: Thread Force Calculations
Calculating Energy per Hour
06/12/2008 4:53 PM
Hi im am looking for some information on how to calculate the amount of energy created per hour from a spinning fan blade in an enclosed PVC pipe of 6" internal diam and the flow rate of sea water is 2.5m/s
Good Answers: 230
Re: Calculating Energy per Hour
06/12/2008 10:18 PM
Hello johng
It's really going to depend on the number of blades, type of impeller, method of connecting the impeller to generator or alternator, and head of water.
Advise further please, with
Kind Regards....
06/13/2008 5:13 AM
Im hoping that you can shed some light as to the most efficent impeller to use also the head of water if i have done the caluclations write is 25kpl
06/18/2008 9:36 AM
Shaft power is applied torque times angular velocity, all expressed in compatible units.
Register to Reply 3 comments
johng (1); PWSlack (1); Sparkstation (1)
