Previous in Forum: How to weld.032 stainless wire mesh .   Next in Forum: Hardfacing of Valve Seat & Trim
Usefull Equations of Air compressor Systems
06/18/2008 1:10 AM
I would like to improve my knowledge on Air compressor Power out /input, air flow delicery versus pressure calculations.
welcome to any body willing to provide these equations
Re: Usefull Equations of Air compressor Systems
06/18/2008 2:27 AM
hi
i can send U by mail 2 files.
please send eyal@aob.co.il
p.s. -where can i share this files at this site?
06/18/2008 7:53 AM
Bud Trinkel
United States - Member - Woohoo Engineering Fields - Mechanical Engineering - New Member
06/19/2008 8:29 AM
From Machinery's handbook (which is a common reference for oil flooded compressor engineers), the HP to compress the air adiabatically is:
HP = [144*N*P*V*n] / [33000 (n-1)] * [(P2/P)^[(n-1)/(N*n)] - 1]
where N = number of stages in which compressions is accomplished
P = atmoshperic pressure in pounds per square inch
P2 = absolute terminal pressure in pounds per ssquare inch
V = volume of air , in cubic feet, compressed per minute, at atmospheric pressure (this is the rated cfm of the machine typically and relates to the intake cfm)
n=exponent of the compression curve = 1.41 for adiabatic compression
This is the HP required at the compressor to compress the air. Now you have factors including efficiencies of the bearing system in the compressor, the motor efficiency, and the drivetrain efficiency that will add to the power required by the motor. For a given compressor you can simplify the problem by measuring the power consumption of the compressor, calculating the theoretical horsepower, and then back-calculating the efficiency of the machine. However, you should note that this efficiency can change with speed, inlet air temperature, oil temperatures (for an oil cooled compressor), etc.
And then you can use the following formulas for calculating the relationship between pressure and volume in adiabatic compression of air:
P2/P1 = (V1/V2)^1.41
where P1 = initial absolute pressure in lbs/ft^2
P2 = absolute pressure in lbs/ft^2 after compression
V1 = initial volume in cubic feet
V2 = volume in cubic feet after compression.
Hope all this helps.
Self-motivational quote: "If they can make penicillin out of moldy bread, they can sure make something out of you." -- Muhammad Ali
06/19/2008 9:27 AM
Nate,
The majority of the oil flooded air compressors followed the polytropic process since some of the heat generated is removed. You happen to have the equations for those too?
01/15/2010 5:05 AM
All this information I read in my thermal engineering book in my diploma....Thanks for sharing with us.
BudT (1); eyal g (1); khangnguyenca (1); Nate (1); wreinmicheal (1)
