Previous in Forum: Usefull Equations of Air compressor Systems   Next in Forum: Welding Method
9 comments
Hardfacing of Valve Seat & Trim
06/18/2008 2:02 AM
Hello freinds at CR4,
I have come across "hardfacing", "stellited" trim a number of times in my valve data specifications. I do know that hardfacing is done to toughen and increase wear resistence to the trims and that stellite is a cobalt cromium alloy. howver, I am interested in knwoing more on this. How is the hardfacing done, how is stellite depositted on the surface? I have been looking into Google but I still am not satisfied. any experts out there who can help?
Thanks.
Re: Hardfacing of valve seat & trim
06/18/2008 7:49 AM
Hi Nithya,
Stellite is deposited on the surface , by welding and by spraying methods . You need the welding machine (preferable Generator dc+) consumable such as the stellite MMAW electrode or barewire for TIG.Stellite is available in various grades and it is advisable to select the one that is specified in the valve data sheet.Both are availabe in the market.Consumable manufacturers/seller will assist in finalising the welding method and setting of parameters such as current , pre-heat, interpass etc dependng upon the material and dimension of the valve seat you are wanting to overlay with Stellite.
The same could also be done with Spraying, (has limitation though , regards to the thickness build-up required as compared to when done by welding) .The spray can be done using HVOF , Metal Arc or Plasma Spray.
In case you find difficulty in getting stelliting, you may consider substituting it by a hestalloy grade after discussing with the valve manufacturer.
The required specialised services are widely available .Please let me know your location so that I can suggest a suitable one.
06/18/2008 11:48 PM
thanks a lot. that was very informative. One more thing i would like to know is: I observed that generally, for hardfacing trims, the hardness specified for the seat ring in the valve body is more than the wedge/gate seating surface hardness... Why is it so?
thanks
Good Answers: 97
06/19/2008 1:38 AM
application
06/19/2008 2:33 AM
Dear Mr. Tyer,
This is a design feture designers are following,as it is less cost to replace the weared out wedge/gate seating parts compared with replacing the body seat ring.The body seat rings are welded to the body or assembled using shrink fit.Removing this ring for repairing activities is a difficult task and usually needs expert.
Sayed Sarhan
Good Answers: 97
06/19/2008 3:15 AM
I'm with ya except that the body rings are parts in a 'globe' type valve and the gate/wedge part is fitted to the stem of a 'gate' type valve.
Re: Hardfacing of Valve Seat & Trim
06/18/2008 10:39 AM
visit Delora Stellite at www.stellite.com Deloro Stellite is a global provider of innovative solutions to challenging wear problems. Our specialist products and services help extend the life of components in demanding environments where heat, corrosion and abrasion limit their life.
06/19/2008 8:15 AM
A weld overlay of stellite (also referred to as Colmonoy) is applied either manually or, more commonly, with automatic welding equipment and then machined to the required tolerences.
06/19/2008 9:54 AM
sometimes the word "stelliting" is used in place of Hardfacing, possibly because Stellite was the first material used for this application. Normally because of the Cobalt contet in this alloy, it is used where temperautres above 3000 F a"re involved, otherwise you can safely use Ni Cr B Si alloys for the hardfacing and these can give different hardnesses as per your requirement. Normally the hardness of a stellite overlay is around RC 40, but the Ni Cr B Si alloys have hardnesses ranging from RC 20 to RC 60 and can be used by spraying or melting a rod of different diameters from 1/16 ti 1/4 inch by a small welding torch to give you a pore-free dense coating. These alloys are stable upto about 1800 F
vshwn7@aol.com
06/19/2008 12:45 PM
Engine valves for the automobile, aircraft and stationary engines used stellite on the exhaust valves.
This was applied by a typical brazing technic of preheating the valve as it rotated and then applying the stellite rod material with a torch. Later in the mid 80's, the company developed an automated process of depositing stellite from a powder but still used oxygen and acelyne with argon.
Register to Reply 9 comments
Anonymous Poster (2); bwire (2); Nithya Iyer (1); Pete (Contol Systems) (1); Repete (1); Susui (1); vishmayor (1)
