Previous in Forum: Hardfacing of Valve Seat & Trim   Next in Forum: Help wanted - regarding Stewart Platform
9 comments
Welding Method
06/18/2008 4:27 AM
Hello. I am working at UAE as a Senior Project Engineer. Our company engagged in Mechanical Construction activities of Storage Tanks & Piping. Can you suggest any Automatic Welding system/machine which we can use for tankage horizontal/ vertical welding.Are these machines are available at UAE? Can you give some address ofpermenant user's of these type machines?
Re: Welding Method
06/18/2008 10:20 AM
Several methods are available. Bugo systems are used in shipbuilding, storage tanks, and so many other applications too many to list. Bugo will also build a system to fit your aplication. They are good people to work with and would be happy to assist you. Try http://www.bugo.com/ or your local welding supplyer.
A good deed not praised holds behind it a thousand deeds yet undone.
Re: Welding Method
06/18/2008 10:36 AM
Sir we are manufacturer of mechanical power press,power shearing machine,treadle shearing machine and vices.
Re: Welding Method
06/18/2008 10:53 PM
Please mail me < mikemahant@hotmail.com>. A>Z Will be supplied. MM
Re: Welding Method
06/19/2008 5:50 AM
5,10,20,30,40,50,80 Ton power press machine..
Re: Welding Method
06/19/2008 10:12 AM
Are you looking for welding equipment or someone to do the welding with the equipment?
Re: Welding Method
06/20/2008 2:17 AM
yes. Iam planning to purchase some machines. Can you give some address where these machines are using in gulf region, so that i can go there and check the feasibility of this type of machines.
Benmathew
Re: Welding Method
06/20/2008 9:32 AM
Ben
I called BUGO Systems and talked to G Meneely about your application. He would be more than glad to provide you with the info that you need. Contact him at: gmeneely@weld.com
BUG-O SystBUG-O Systems Inc.
A Division of Weld Tooling Corporation
World Headquarters:
3001 West Carson Street, Pittsburgh, PA USA 15204
Phone: (In U.S. and Canada) 1-800-245-3186
International Calls: 1-412-331-1776
Fax: 1-412-331-0383
Re: Welding Method
07/06/2008 12:22 PM
Where are you on this project?
Re: Welding Method
07/08/2008 4:37 PM
If the storage tanks are of more than 7 M dia, you can try MIG welding.
Register to Reply 9 comments
BENMATHEW (1); MUKULMAHANT (1); Randouli (4); srijitpv (1); sudhirpatel (2)
