Previous in Forum: Design of Elliptical Pad/Cover for sight glass   Next in Forum: Cooling Equipment for Telecom Switch/Server Room
electrical oven
06/19/2008 1:59 AM
i wat to get all parameters (fabrication as well as control )of an elecctrical industrial oven -4kw to 6 kw range with 60 to 100 degree celcious temper.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
Re: electrical oven
06/21/2008 1:35 AM
Hi, pgsath!
Welcome to CR4. It's always nice to see new people joining up and posting their first blog. I hope you get a lot of good responses to your question.
I'm curious to know, from the point of view of being as helpful as possible, what the industrial oven will be used for. Also, what kinds of searches have you already done for the information you are seeking? These two pieces of information will tell me if I can offer anything by way of assistance.
For example, are you drying paint or baking coatings (or bread)? Does the product pass through the oven like pizza or glass, or stay inside, like ceramic ware? Does the process require timers/automation? Is it close to people on the industrial floor? How big is it? Telling me what you will be using it for will answer these questions.
And do you want to build your own? Get a used one? Modify an existing one to your use? Have one custom made for your application, which could be a well known one or a novel application of some sort. Finding out where you have already looked, or if you have looked without any success will help me discover the type of brand/application variables you are considering.
Mark
Re: electrical oven
06/25/2008 6:39 AM
thanks for the response.
i want ot make an industrial oven -on my own design but with proper guuide lines of experiened persons like you
it will be a n electriacal oven which may be converted to biogas fired one in the future .5 kw capacity with 24 tray oven having thermostat control and a blower.
i want tro dry washed herbs /raw materials of ayurvedic meicines-about 100 kg /150 kg capacity
insulation?
control?
size?
fan requirement?position of the fan ?capacity of the fan ?
design/drawing of the tray oven -provide all of these for me to get only a wonderful and everlasting thankful heart .thank you
satheesh
aluva
keralam-india
Register to Reply 2 comments
