Previous in Forum: Power plant expansion   Next in Forum: Work Procedure for maintain and repair package transformer substation
4~20mA Signal.
06/20/2008 3:42 AM
Dear Sir ,
I make a 4~20 mA signal circuit diagram on PCB Board . I give in put 24VDC this circuit & get output 4~20mA.Tell me how i make this circuit & what things is required .
Re: 4~20mA Signal.
06/20/2008 4:10 AM
It's an intersting study exercise.
These things are also available commercially.
Re: 4~20mA Signal.
06/21/2008 4:24 PM
i know these things are available in markeet but it is not possible to get easier every person because it is very casstly
Good Answers: 46
Re: 4~20mA Signal.
06/22/2008 12:17 AM
Hello Imran Hussain, The simple way to generate a signal would be to use a resistor for a single milliamp. If you want to do a range from 4-20mA then a resistor bridge with a variable resistor could be used. Best to use precision resistors and multi-turn resistor with values picked for your range or a little above and below what your needing to read.
This way is a just a quick test to do a range. If you need accuracy or for calibration then one of the processor meters like from Fluke would be a good start. They can generate the test voltage, the test current and they can read and or measure the same.
Oh one other thing most loops need a limiter resistor typically 250ohm in series is a good value and as a bonus you can read a voltage across the resistor 4-20mA = 1-5vDC.
Generally you would have a power supply "+" side goes to a sensor "+" in then "-" out to the meter/recored "+" in then "-" out to the power supply "-" to complete the circuit.
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Register to Reply 3 comments
Anonymous Poster (1); metalSmiths (1); PWSlack (1)
