Previous in Forum: calibration   Next in Forum: RC Wall Design
emergency dike construction method
06/21/2008 2:14 AM
ie: The continuous sandbag : A large bolt of heavy canvas perhaps hempen canvas if can be aquired , the lenght of the bolt for our discussion shall be 150 ft the width of the bolt some 16 feet or so . at the perimeter of the layed out canvas shall grommets be set quite a lot of them . The front loader or shovelers or bothe shall fill the center of the bolt with sand such that enough room is left to be able to draw the grommeted sides and ends of the fabric in and 1/4 inch steel cable can be used to " sew the bag together" it may also be done that a 4" dia steel pipe 170' in length oa would span the centerline of the bag and the 1/4" cable would be weaved thru the grommets and over and under the steel pipe in a helical fashion . The pipe shall also have tee or four way fittings at selected intervals in order to accomodate multiple pump actuated drainage pipes to the front or waterside of the levee. That accumulated water would be pumped away . So course after course of continouos sandbag would be layed atop the first one as needed or defined by the anticipated water overage problem . of course each increase in height shall be achieved by laying an empty bolt (grommmeted) atop the existing and filling it in place ?To expand on this concept for a permanent mechanism would require that there would be an increase in the number of teed and or four way sections to facilitate the placing of cement board (wonder board) with holes drilled in the boards via a holesaw to accomodate the exterior diameter of the threaded sections (waterside) emanating from the tee . That the holed wonder board shall be placed over the protruding outward from the bag tee connections and threaded fasteners shall be threaded onto the 4" pipe protrusions thus securing the wonder board in place . tiling of surface can now begin addendum as this is a permanent design a waterproofing or rubberizing of the hempcanvas might be prudent ?also cement might be pumped in between the wonder board and the csb and the wonderboard retaining fasteners could be torqued in such as a fashion and at various intervals ( of time) to maximize the curing process of the cement to obtain maximum rigidity of structure ?So then four ways as opposed to tees is the way to go ? And multiple layers of wonderboard some tee sections would be exposed to the water others would be capped ?cement on both sides of the csb may be necessary ? it may not ?
Re: emergency dike construction method
06/21/2008 4:56 AM
Interesting concept...
I think the Tees and fitting for pumps are an unecessary cost/compliction.
I think the water seeping into the sand is part of the reason the sand bag works as a barrier.
06/21/2008 5:45 AM
I think you'd have a problem after the first layer (which sounds good), in that the sand wouldn't stay along the centre-line of the second bolt - it would just run off to either side (unless the sides were supported somehow until they could be "sewn up").
Good Answers: 15
06/23/2008 6:10 AM
Wouldn't you have to put a 2nd tube on the bottom then the 3rd tube on top in a pyramid formation to give it enough base to be stable enough for upper layers.
I like the concept. Since we are currently fighting the Mississippi & the Missouri Rivers here. I've been trying to figure out a better way of building sand bag walls.
How would you reinforce the areas around the grommets so that the weight of the sand wouldn't tear the fabric as you are tying the two sides together?
scotchdrnkr
06/27/2008 2:17 PM
Yes as you say it is just a " concept " at this point . Ive been doing some thinking since my original post and have some revisions . The hemp canvas that ive described exists and is an extremely heavy weight oily type canvas. Whether its available in a bolt 16' wide is doubtful at this point in time ? The pronounced width is to accomodate the depositing (via frontloader) of sugar sand such that when the bag is sewn up its finished dimensions are 6' wide and 2' high .As for the 4" ID steel pipe along the centerline and the accompanying tee'd sections ,atop the centerline pipe there would need to be deposited some dry mix maybe 3/4's sand mix and 1/4 portland to keep the weight of the sand from distorting the pipe ?Also the tee'd sections could not be tee'd at all they would have to be 4 ways ? And the protrusions from the four ways would be 6' or 7' in length themselves to facilitate multiple layers of wonderboard ? The first layer to be about 18" from the bag(s) ? Steel re-enforcement such as rolled steel mesh wire would be placed between each layer of wonderboard prior to the pour . The csb would be saturated with water just before the pour and the only tourquing of threaded fasteners during concrete set up would occur at the outer most layer(s) of wonderboard on both sides of the csb? The end result being a wall 12' wide with a concrete expenditure of a 5' wide wall ?
04/12/2010 9:19 PM
02/09/2022 4:17 AM
Lay a tarpaulin on the ground and lay Hesco barrier on top , fill the hesco with rock / sand / anything , lift the tarp up and tie it to the top of the hesco for waterproofing.
job done
These things are self explanatory but you could go up to 6 feet
I think these are best , fast to set up , low transport weight , seal the pressure side with a tarp and the water compresses the seal if they are 40 degrees or lower
Good Answers: 128
02/09/2022 7:15 AM
Long-term is when we find our dikes, barriers, and similar approaches to be just delaying tactics. 100-year and 500-year floods have all become more common than the predictions because of changing weather conditions (they are now 20-year and 50-year floods). Good soil in the river bottoms and flat areas all encourage regular agricultural use and construction of buildings, etc. Therefore we build levees, but this limits the area over which water can flow, causing the "flood" heights to increase. The history of floods in the Mississippi river give good examples of this--I suspect that in the next 50 years or less that river will change channels at the Atchafalaya and completely bypass its existing mouth through New Orleans. A flood of the Mississippi river system 95 years ago destroyed or bypassed hundreds of miles of levees, with 1,000,000 people displaced for months and the waters covering areas as wide as 100 miles.
We think we can control the world. Not likely. Better to cooperate than compete, but that goes against our "nature".
Building thousands of small water retention ponds in farm lands has repeatedly shown substantial reduction in downstream flooding while also improving moisture content in the soils. Big dams have undesired side effects such as depleting soil downstream, becoming filled with sediment, blocking fish migration, etc.--although they do control flooding up to a certain point when they can be over-topped and fail catastrophically or their spillways overflow and massive flooding occurs downstream.
Register to Reply 7 comments
Anonymous Poster (1); jmueller (1); JohnDG (1); Nothing is Impossible (1); peltonair (1); scotchdrnkr (1); user-deleted-1105 (1)
You might be interested in: Cement Boards, Cement Tiles, Bolt Tensioners
