Previous in Forum: grounding & earthing?   Next in Forum: ELCB SENSITIVITIES
12 comments
cable size selection
06/22/2008 2:15 AM
How to select proper power cable size? i want to know that formula? and cable size selection chart according to KW/VOLT
Good Answers: 230
Re: cable size selection
06/22/2008 3:06 PM
Hello kumarnaik
This is a perennial question.
That means it keeps being asked repeatedly here at CR4 Forum.
Use the facility at right: "Search all of CR4", and enter the Search Terms.
Just to start you off, refer here: http://cr4.globalspec.com/thread/11833/power-cable-rating
I used the Search Terms: Cable Table
Trust that assists you.
If you need further help, reply here, with
Kind Regards....
06/23/2008 4:22 AM
Use a larger cable than the code requires and you will not starve the eqwuipment for power causeing overheating and lowering the usefull life of the equipment.
06/23/2008 12:24 PM
This is accounted for by derating properly
Tell 'em what they need to hear; not what they want to hear!
06/23/2008 8:08 AM
Sizing a cable is a bit more complicated than simply looking at a table or pulling up a formula. You have to consider the environment the cable sees, you have to consider the load characteristics, motor? computer? Incandescent lamps?... Hire an electrician you cheap SOB and get it done right.
06/23/2008 9:25 AM
Simple answer! Get a copy of the American "National electric Code'' and it will simplfy your requirements especially since it considers temperature restriction of the type of insulation used.
06/23/2008 11:05 AM
Please refer to the current edition of the Wiring Regulations, published and maintained by the IEEE.
06/23/2008 12:07 PM
There are numerous factors that need to be considered:
  1. Feeder or branch circuit (different multipliers for derating)
  2. ampacity required
  3. copper or aluminum
  4. ambient temp
  5. free air or in a raceway
  6. distance (to calculate voltage drop)
Yes, I'm a licensed Journeyman
06/23/2008 12:09 PM
I forgot. When all variables are calculated refer to Table 310 in the current Nat'l Elec. Code
06/23/2008 12:22 PM
Sorry wasn't logged in
06/23/2008 4:48 PM
When we select cable then we calculate these things.
1. Air temperature .
2. Load current ( how many load (current)on this Cable we used ).
3. cable capacity(all company allow cable maximum load capacity)
4. Voltage drop calculations:
5. Running voltage drop.
6. Distance (cable length)
7. cable laying ( under ground or open laying)
8. cable type ( 2 core , 3core,4 core).
these all things calculate then we laying a cable.
Note. All company give a chart where note cable maximun ampere capacity.
10/20/2008 12:33 PM
how to calulate voltage drop in cable?pls tel me the pormula
Good Answers: 230
10/20/2008 7:53 PM
Hello again, kumarnaik
There is no single "Magic Formula", except Ohms Law, modified for the particular usage you intend..
There are many variables, as you have been advised above.
Consult the Maker of the cable you intend to use, and use that Maker's Cable charts for the actual type of cable you intend.
Those charts will advise you about deratings too.
Kind Regards....
Register to Reply 12 comments
Anonymous Poster (4); dadw5boys (1); kumarnaik (1); noshorts (2); PWSlack (1); Sparkstation (2)
