Previous in Forum: anti-fouling in line tube for pre-treatment of water   Next in Forum: How to tell 201 grade stainless steel from 304 grade stainless steel
Survismeter, Econoburette, Green Chemistry, microscale
06/22/2008 12:55 PM
Now time has gone of using viscosmeter and stalagmomter for viscosity and surface tension, interfacial tension study individually. The survismeter, a single apparatus, serves their purpose for above parameters simultaneously. Allows no effluent to drain out and reduce manifold operational steps to few. This measures surface tension and interfacial tension with pendant drop method. Pressure gradient is an operator for lifting the liquids from reservoir bulb to functional bulbs via respective cappilaries. Surya Mani Kumar, successfully measured the said parameters with survismeter, he found survismeter user, eco and environmental friendly device for undergraduate, graduate, research & develoment centres, University servise instrumentation centre {USIC), central servise Instrumentation faclity (CSIF), and many industries like inks, sol-gels, fermentation broths etc.
Re: Survismeter, Econoburette, Green Chemistry, microscale
06/22/2008 1:29 PM
Errrrrmmm and so...?
Good Answers: 230
06/22/2008 2:08 PM
Hello Guest,
Some of your spelling is incorrect.
Now you may go back to your statement above, and try and locate the mis-spelled words.
Kind Regards....
