I am building an axial flux generator (Wind Turbine Driven). I am using neodynium magnets on the rotor. The rotor diameter will be approx 1200mm(4ft). I know that there has to be a certain amount of mild steel in the rotor for the best magnetism. I am cutting out the center of the rotor and just leaving spokes to attach to the center hub. This is for better air flow to the stators and less wind resistance at the center of the turbine. I intend to leave a band of steel approx 200mm all round the edge of the rotor onto which the magnets will be attached.This generator will be around 10KW output. Based on this information I wonder how thick should the steel of the rotor be to get best results. Also if I used rectangular neo magnets 3"x1"X1/2" what would the best spacings be for them on this size of circle.
All help appreciated.
