Previous in Forum: Yamaha Motorcycle refurbishing   Next in Forum: how to read Shift Maps (TPS vs Speed)
13 comments
Throttle Body Spacers
06/24/2008 1:21 AM
Do TBS's really work? Not as far as adding anything since I know the motor's computer will only allow so much air to mix with the fuel. But do they do their job of creating a vortex of air? I'm just curious if the "threading" really does what it's advertised to do. Also, is the vortex created any more powerful or controlled using less air compared to a burst of air at the same psi?
Re: Throttle Body Spacers
06/24/2008 2:48 AM
Tuning the length/shape of an inlet manifold is proven technology.
However it makes the assumption that the original design wasn't optimised...unlikely on a modern car....
Basically a moving column of gas has momentum, (plus angular momentum if its spinning) this can be used to ram air/fuel mix into a cylinder even when the piston is on the way back up.
If you had a very old single cylinder 2 stroke, then playing around may be worth while. Or if you are tuning this engine for a very specific purpose/rpm.
Otherwise, save your time and send me your money.
06/24/2008 8:26 AM
I remember *nostalgic moment approaching* in the late 60s most motorbikers would fit carburrettor spacers because of the reduced heat transmission from the cylinder to the carb...
The same as fitting 'trumpets' to the inlet to your Amal carb...
John
Good Answers: 123
06/24/2008 8:00 PM
There are spacers that go between the throttle body and air cleaner that claim to add a swirl that helps to get better fuel and air mixtures. This would seem to be possible only when at WOT (wide open throttle) or very near. Throttle body spacers that go under the throttle body or carburetor, would be able to change the efficiency at WOT. But only at a specific RPM. Adding more space under the throttle usually will lower the RPM that an engine makes torque at. There are reports that the GM throttle bodies were restrictive between the throttle body and the injectors on the early throttle body injection systems on the v6 and v8 engines. In these engines it was possible to remove the injector housing and add spacers to raise the injectors. This was supposed th aid air flow. I thought that only a 3/8" stack of gaskets was needed to pick up the air flow. What was the application you had in mind.
Bob
Good Answers: 16
06/24/2008 10:57 PM
Good explanations! I'll add a secondary benefit to the spacer-typically less engine heat is transferred to the carburettor and this reduces the volatile pressure in the fuel bowl-thus greatly reducing the possiblity of a vapour lock.
Best Regards,
Ing. Robert Forbus
"Yeah, but will it fit?"
Good Answers: 15
06/25/2008 12:51 AM
Huh? run that over me again??
Vapour lock in the carby fuel bowel? How? most carbs I have worked on are vented to the intake above the butterfly, so if there is any pressure, it will escape then get sucked into the induction as you open the throttle.
And I thought vapour lock was in the galleries of the carby or fuel lines...
Chuck the carb, and inject the bugger ;o)
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
06/24/2008 11:05 PM
My intention was to take that technology and apply it to a paintball bolt using compressed air. Nothing to do with cars, but looking at the technology being used in any industry and think outside the box.
Good Answers: 15
06/25/2008 12:53 AM
you mean rifling the barrel to get a "Spin" on the projectile?
look up Rifling -> http://en.wikipedia.org/wiki/Rifling
06/25/2008 1:02 AM
Not rifling the barrel. I'm not looking to spin the ball in anyway cause then it would turn into that of a curve ball. I'm looking at it in terms that a burst of air like what a grenade makes wastes too much energy. So if i was able to make a vortex of air it would offer more power and consistancy. THEN possibly with a rifled barrel with the right amount of twist rate offer better trajectory. Just trying to think of something to get more bang for the buck. I should draw something to illustrate my idea.
The best way I can think of that offers more energy using a vortex is like a forge. Some use a tube and the gas circulates creating more heat using the same amount of energy. Or like the turbine engine on a jet, creating more thrust.
Good Answers: 15
06/25/2008 2:27 AM
turbine uses vortex to get more thrust?
where?
In a turbine, you have alternating compressor and stator vanes, the compressor as it spins, makes the air rotate in the disc as it passes thru, the stator blades straighten the air flow before it hits the next set of compressor blades, the same arrangement in the prime mover at the other side of the combustion chamber.
Your trying to get more gas charge as you fire the paint gun?
adding holes to "suck" in extra air will get tricky, and may end up defeating the original design, you may need to look at increasing your charge capacity, or a different propellant, like gas injection and ignited, or wrap the charge cylinder in a heater loop, or peltier devices, and inject liquad-air into the chamber, the heating of the chamber will convert it into much more pressure ;o)
Good Answers: 123
06/25/2008 9:18 AM
There is only so much energy in the timed shot of compressed air. You are dealing with a hollow tube closed on one end. Without drastic changes to the barrel I don't think you will gain significant improvement. Why don't you concentrate on a longer timed release of air into the barrel.
Bob
06/25/2008 2:39 AM
D'oh.
The moral is ask the question you actually want the answer for. I've run out of enthusiasm for this now.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
06/24/2008 11:33 PM
The short answer with so little data is "yes" it is possible the effect engine performance with spacers.
The longer answer is on my 4.0 liter inline 6 jeep engine with a stock 50 something MM throttle body it ran ok. I installed an after market 60MM throttle body. It showed a little more low end power and much better response from 3500 rpm up.
I added a AIRAIDE throttle body spacer that was threaded on the ID. It was built for the stock throttle body. Lower end RPM's should little change, RPM increase fro 3500 up was faster. The real change was when I took the throttle body adaptor off and into my corner father and son machine shop and ask the to increase the ID. The results were three fold, low end response was noticeably stronger, I felt a "turbo type of effect" starting at 1800 RPM's that got stronger all the way up to the 5500 rpm rev limiter shortening my 0-60 mph time by 2.5 second ,when I drove reasonable I gained 2 MPG.
The real test is on a very hot day working my jeep in steep hills or heavy into the rocks I can load the motor to below idle speeds 3-500 rpm and stand on the throttle and the motor always pulls me through.
For the deep thinkers I would say if we examine the three T's of combustion Time, Turbulence and Temperature my modification has increased turbulence only because I am causing a lot of rotation below the throttle body butterfly plate.I have cooled the air (a little) by raising the throttle body, ultimately allowing a greater combustion chamber temperature by better mixing the fuel/air prior to entrance into the cylinder.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
06/25/2008 8:50 AM
If Im not mistaken, many paintball models use venturis to improve how the gas acts upon the ball - I think you may be essentially reinventing the wheel when it comes to your idea.
Register to Reply 13 comments
Anonymous Poster (1); bob c (2); Electroman (1); Ing. Robert Forbus (1); MichaelWied (2); miketheboilerguy (1); Snaketails (3); user-deleted-1105 (2)
