Previous in Forum: List your prescription drugs.   Next in Forum: reply pls
9 comments
My Poulin Riding Mower
06/24/2008 2:25 AM
i have a poulin riding mower as I was mowing out of nowhere it made a lark clunking sound put out a little smoke I think fro a belt draging and now it wont crank. It also will not light the lights wneb they are turned on. It seems to try but it's like it is locked up?
Re: my poulin riding mower
06/24/2008 3:07 AM
"... it made a lark clunking sound ..."
Don't say this too loud - the lark is a protected species in some countries .
06/24/2008 5:41 AM
I'm guessing you hit a rock and bent or broke the crankshaft. Flip it over and look at the blade it should tell the story .If the motor is seized replacements from Northern Hydraulics or similar magazines offer cheap replacement engines rather than attempting to repair your engine. While manually checking motor to determine if it is locked up disconnect the spark plug for safety and ease of turning motor . Make sure there are no obstructions jambing things up like a branch as well.
Lighten up
Reply Off Topic (Score 4)
Hobbies - CNC - New Member United States - Member - New Member
06/25/2008 7:49 AM
As this is a riding mower I doubt that the crankshaft is bent due to hitting a stick or rock. The spindles that the blades attach to are belt driven. That is unless this mower uses hydraulic motors and electric clutches. More info needed. My wife routinely drives over short tree stumps and piles of rocks. She has bent the blades, the mowing deck, and a few spindles and never had any crankshaft problems. It is possible that a stick was caught between the belt and drive pulley. Then it was flung into the wiring. As this happened it could have caused the belt to roll over a guide or other fixed component and it is now hung up preventing the motor from turning. There should be 2 drive belts. One for the transmission and another for the blades. Check both. This is speculation based on experience. More info is needed. Which model of of mower do you have? Lawn conditions: short grass, tall grass, pasture? My wife mows a trail through our woods with the rider instead of using the rotary behind the tractor.
Reply Off Topic (Score 6)
Re: My Poulin Riding Mower
06/24/2008 10:55 PM
You report a sudden change in peroformance after a loud noise. You suspect belts were involved and you saw smoke. Now the electricals don't work and the motor will now turn over.
As recommended by post #2, check the mower plate, but also look at the shaft where it goes "up" through the deck.
You might have snagged the electrical wiring, some rope or even a drive belt around the driveshaft and that has tightened and has stalled the mower.
Remember ALWAYS sparkplug unplugged (or even removed) before attempting to spin the plate by hand to see if it's tight.
06/25/2008 6:20 AM
Sounds like you may have been low on oil and overheated the mower which caused a dropped valve that then caused a sheared flywheel key when the engine was stopping from high speed.
06/25/2008 9:08 AM
Ouch... harsh end to the life of the Poulan.
Live Slow - Sail Fast
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
06/25/2008 10:34 AM
One addition to the above. The lights on riding lawn mowers typically are linked to the generator not the battery. Therefore they will not light unless the mower is running.
If necessity is the mother of invention then is laziness the mother of necessity?
Good Answers: 12
06/26/2008 2:23 AM
Guest,
Thinking it through...at the center of all your described symptoms--ignition circuit, headlight circuit, and starter circuit--is the multi-pole, single/momentary-throw rotary starter switch. So that is your starting point for solving the problem (and quite likely the problem as well).
Explaining further:
  • Riding mower headlights (switches) are not fed from battery but elsewhere, most likely the starter circuit. By design, starter switch must be at ON to enable headlight switch-on...to prevent accidental discharge and ensure optimum voltage for engine starting.
  • As you were mowing, an interrupt occurred in the power to the starter switch ... it could have been a switch ground fault (or ignition module or other ground interrupt) which would have immediately killed the engine...same as if you had turned of the switch manually to ground the armature and kill the engine.
  • The clunk was probably only a reaction in the engine or mower blades...not likely significant OR..
  • The clunk (most likely) came from the electric PTO (mower drive) clutch...if mower-engage is started with a switch and not by a manual engage lever.
  • The puff of smoke...same thing as blade and engine continued turning with no spark to burn the fuel...or blow back from intake valve.... Again, probably not something to worry about.
So work the problem as an electrical problem. Tag, disconnect and remove that starter switch (you can test in place if space permits); then check continuity for all switch make-break circuits in all switch positions. If you don't have reference to your mower's switch schematic (in your manual or part manual drawings), make your own as you check switch make-break continuity-discontinuity. Also check for shorts (incorrect continuity between what should be isolated make circuits in the switch. Possible you might also see burn tracking during visual inspection. ) This (fixing or replacing of that switch) should solve your problem. But if the switch tests good...
Then you will want to trace out and assure continuity in (first) battery-switch circuit (including ground), then starter, then ignition to find the interrupt or ground fault.
Good luck with it...and also, what engine in the rider?
Oh yes! Another electical possibility would be with a failed safety interlock switch:
  • Dead man switch in seat (kills engine if operator leaves or leans too far out on seat)
  • Blade clutch switch lockout (prevent engine from being started with mower blade drive clutch engaged)
You can isolate (disconnect leads from) and manually operate any of these switches while checking make-break with ohmeter.
06/27/2008 12:56 AM
Just pack it up and ship it back to Arkansas, where it was born, and they will bury it under the rocks..
Anonymous Poster (1); CaptnPea (1); CowAnon (1); dadw5boys (1); double_j_b (1); JohnDG (1); Just an Engineer (1); The Mechanic (1); traditional (1)
