Previous in Forum: What Dos Codes Prompt Program Loads of HP Celeron Windows ME?   Next in Forum: Unix Problem
error 1304.error writing to file c:\
06/30/2008 4:24 AM
error 1304.error writing to file c:\Documents and settings\All Users\Application Data\Kaspersky Lab\AVP8\Bases\neurald.avz verify that you have access to that folder.
Any one can help please.
Re: error 1304.error writing to file c:\
06/30/2008 7:28 AM
Guest the best way to find out what to do about error codes is to enter 'error 1304' into Google and check the results...
There are 363 hits on this page all dealing with error1304
http://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rls=SKPB,SKPB:2006-46,SKPB:en&q=error1304
And if you put a space in 'error 1304' the search comes up with 5,200,000 hits!!!!!!!
Courtesy of Lord Google.....
How To Fix This Error
We Invite You To Browse SmartComputing.com!
Error Message:
Error 1304: Error writing to file X.inf. Verify that you have access to that directory.
Translation:
Files that end in the .INF extension are information files, and they're crucial for the installation of hardware. Windows stores all INF files in a single directory, so it knows where to find them, and this directory can hold thousands of INF files. It can quickly fill to capacity because many programs and devices create zero-byte INF files when they're installed. These files are empty but still take up space in the directory structure. You'll need to delete them to make the Error 1304 message go away.
Solution:
Click Start, expand Search, and click For Files And Folders. Type OEM*.INF in the Search For Files Or Folders Named field, and don't forget the asterisk (*) because it acts as a wildcard. Type C:\WINDOWS\INF in the Look In field, click Search Options, and put a check in the Size box. Select At Most 1KB, check the Advanced Options box, and remove the check from the Search Subfolders box.
Expand the View menu, click Details, and click Search Now. When the search is complete, expand the View menu again, expand Arrange Icons, and click By Size. Scroll through the results list until you find the first 0KB entry. Click the entry to highlight it, hold down the SHIFT key, scroll down to the last 0KB entry, and click that entry. Now all the 0KB entries should be highlighted, but double-check to make sure you didn't select a 1KB or larger entry. Once you're sure that only 0KB files are highlighted, press DELETE and wait for Windows to clear the files out of the INF folder. Reboot and you should be able to install your hardware without triggering the error message.
John.
Good Answers: 68
07/04/2008 4:02 AM
Hello Guest,
as far as I can see after doing a google search for error1304, the problem relates to
Do You Have Problems With Error 1304?
Cause: Error 1304 is caused by missing system files or very damaged system registry structures.
Regcure says it can fix this problem. But I have never tried it though I do intend to download Regcure for a full check on my Registry.
What Enviroman says is good advice I do not have enough knowledge to put it better than him..............But, trying regcure probably will not hurt your machine and if, as I read, it does mend your Registry and therefore stop this error message it has to be worth a try?
babybear
03/27/2021 6:15 AM
There are two ways you can resolve this issue: Disable all Anti-virus, Desktop protection, and Local Firewall protection through Windows Service Management. ... Configure your Anti-virus, Desktop protection, and Local Firewall protection to temporarily “trust” files that produce the 1304 Error.
Regards,
Caleb
babybear (1); caleb_cruze (1); Electroman (1)
