Previous in Forum: Discharging P.F.C Capacitor Banks.   Next in Forum: GE -MM2 Motor Protection Relay - Starting Current in mm2 Mis Match with Measured
9 comments
Calculate the Voltage Drop of Busway
07/02/2008 4:34 AM
Hi guys,
I find that in the catalogue of most busway supplier, they provide the table and formular to calculate the voltage drop. the formular (line-to-line) is:
Vd(table) = I (load) x (Rcosφ + XSinφ)x L ( where L is the length)
Vd = Vd(table)x (I/In) x L/100ft.
But in table, the Vd(table) is increased when powerfactor is increased. Is it possible?
For example, With 100m of 1000A Busway, Vd (table) = 10.53V where P.f = 0.8. R =5.41ohms*10Exp(-3)/100m. X = 2.92ohms*10Exp(-3). and Vd(table) =9.67V where P.f = 0.6.
and I don't know to tell line-to-line Voltage drop and Line-to-neutral voltage drop apart.
Someone pls help me!
Thank you all!
Re: Calculate the Voltage Drop of Busway
07/02/2008 12:05 PM
To answer your first question, if you look at the equation for Vd(table), the "cos(theta)" term is your power factor. As cos(theta) approaches 1, sin(theta) approaches 0. Since the resistance is greater that the reactance, the voltage drop increases as you approach unity power factor.
For the second question, I think the line to line voltage drop refers to the drop to the load and back when connected line to line, and same for the neutrally. I sure someone will correct me if I'm wrong.
07/03/2008 5:39 AM
Because i don't know how to attach file in this rum. so Pls give me your email addr. I'll send you file and you can see this problem more clearly.
Thank you!
07/03/2008 10:55 AM
Just exactly what kind of file did you want to send? If it is an image of some type, you may be able to insert it using that little camera icon when you post a message.
07/03/2008 10:09 AM
Voltage drop increases as the gap between the load power factor and busway power factor grows.
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
07/03/2008 7:22 PM
See phasor diagram below.
Although the magnitude of resistive and reactive volt drop of the cable (phi in the diagram below) remains the same, it must be added (lagging) or subtracted (leading) depending on the power factor of the load (theta in the diagram below). You need to read a cable volt drop text book or standard for more detailed explanations. Busduct tends to have a higher reactive component than cable so the effects are greater.
Line-to-line is the 3-phase volt drop. Line to neutral is the single phase volt drop. You should use line-to-line if you intend the busduct to feed a balanced load.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
Good Answers: 19
07/03/2008 11:29 PM
Great.
Ramesh,Freelance Electrical/automation Consultant
07/12/2008 9:30 AM
How did u do it? great .I would love to know the tehnique.
03/16/2010 7:13 PM
Phasor diagram is not correct!
Angle Φ is between IRc and IZc
Radomir
03/17/2010 1:09 AM
Anonymous Poster (1); BabyGuinness (1); Blitz (1); Lendog (2); nesubra (1); pradomir (1); ramvinod (1); Tuan_vn (1)
