Previous in Forum: What is the moment Load   Next in Forum: Reg. Elbow Area Calculations..........
energy density of CNG at 3600 PSi
07/02/2008 9:12 AM
Hello, i am trying to calculate the energy density of CNG at 3600 PSi.
I know that at 3600 psi CNG has an energy density of 266000 Btu/ft^3 or 2753022.11 watt-hour/m^3. I would like to convert this to watt-hour/kg and hence need the density of CNG at 3600 Psi.
By my calculations, this comes to around 207514 Kg/m^3. this in turn gives an energy density of 13.27 watt-hour/kg which just sounds too low. am i making a mistake anywhere or is it right?
Can someone help please.
Re: energy density of CNG at 3600 PSi
07/02/2008 5:37 PM
Methane 100 moles/hour
TEMPERATURE DEG F 60.00000
PRESSURE PSIA 3614.000
ENTHALPY BTU/HR -129743.7
ENTROPY BTU/R/HR -1258.874
VAPOR FRACTION 1.000000
PROPERTIES TOTAL VAPOR
FLOWRATE LBMOL/HR 100.0000 100.0000
MOLECULAR WT. 16.0430 16.0430
ENTHALPY BTU/LBMOLE -1297.4370 -1297.4370
ENTROPY BTU/LBMO/R -12.5887 -12.5887
CP BTU/LBMOL/R 13.5698
CV BTU/LBMOL/R 7.6169
CP/CV 1.7816
DENSITY LB/FT3 12.0997
Z-FACTOR 0.859352
FLOWRATE FT3/SEC T-P 0.036831
MMSCFD STP 0.910626
VISCOSITY CP 0.023171
TH.COND BTU/FT/HR/F 0.039636
STREAM CRITICAL TEMPERATURE (CUBIC EOS) F -116.4
STREAM CRITICAL PRESSURE (CUBIC EOS) PSIA 673.1
TS IS STANDARD TEMPERATURE AT 60.00 DEG F
Good Answers: 137
07/03/2008 5:25 AM
You seem to be going about this the wrong way round. The calorific value per unit mass is the more basic figure.
Doing a couple of checks on expected density at 3600psi and expected CV, it looks like your gas is mainly methane. Then net CV ~ 50MJ/kg = 13889watt-hr/kg.
Also if you know the Btu/ft3 quoted by gas supplier, at supply pressure to appliances just above atmospheric, and you know or can estimate density at that pressure, you can work out watt-hour/kg.
You're a factor about 1000 out (depending on just how you do the calcs) in your 207514 kg/m3. Dividing 266000 Btu/ft3 by 50MJ/kg gives 198kg/m3, roughly as calculated for methane at 3600psi.
Advantage of mass CV is it is pretty constant for various fuels. For all the usual hydrocarbons above about butane it's 44MJ/kg (net CV). This is figure used for petrol, diesel etc. It rises a bit thru propane and ethane to 50 for methane.
Incidentally, couldn't assume your natural gas is methane. I have data on nat gas in USA which has CV per ft3 2.5 x higher than methane so has higher molecular weight. Also nat gas (in UK anyway) has some higher MW gas in it, so has higher volume CV than pure methane, but somewhat lower mass CV.
Cheers....Codey
07/03/2008 10:44 AM
Damn youre right. I was wondering what is it that i was doing wrong. its not the KW h/kg that changes but the BTU/Ft^3 because the mass remains the same, its the density thats changing. cant believe i actually made the mistake when i used the calorific value to calculate that of diesel and gasoline.
07/30/2008 4:01 AM
a kilogram of nat gas is equal to 1 1/2 litres of gasoline.
a 77 litre tank held 11 kilos of cng at 3300 psi.[former truck]
go to "http://encyclopedia.airliquide.com/Encyclopedia.asp?gasID=41"
55% of air density. good luck
Register to Reply 4 comments
Codemaster (1); pretzel (1); sahasushank (1); vicini (1)
