Previous in Forum: energy density of CNG at 3600 PSi   Next in Forum: ball bearings
11 comments
Reg. Elbow Area Calculations..........
07/02/2008 3:28 PM
Hai...
This is Prem from Qatar..........working as an Mechanical Engineer in Qatar Gas 3 & 4 Project.....
Recently when my colleagues & myself were discussing about Surface area calculation for ELBOWS and we found different solutions within us..........
So i need your help regarding this issue......Please send me detailed calculation steps involved in elbow surface area calculation.....
waiting for Your favour........
Good Answers: 243
Re: Reg. Elbow Area Calculations..........
07/02/2008 9:03 PM
why not post your work so our experts can point out what they think is going on?
milo
Good Answers: 230
07/02/2008 10:11 PM
Hello Guest,
As Milo states above, it would be best for you to publish your present calculations, then those may be discussed.
Meanwhile, a few general observations may assist.
Surface area for an elbow is proportional to inclination of the elbow with the surface, directly related to the pressure exerted on the surface, the amount of available space on the bar-top has to be taken into account, along with the tipsiness of the elbow owner.
In short, if the tipsiness quotient is exceeded, then the elbow falls off the bar-top, despite the coefficient of friction or any other earlier-listed factors.
That's my short thoughts, and may be modified once you place your present findings here, for examination and discussion.
There may well be a more mathematically inclined Member here, who is able to put the above simplified explanation into an expanded version, then into a proper equation, for future data processing.
Trust you have been assisted.
Kind Regards....
07/02/2008 10:55 PM
well you can draw it and measure in a cad 3d software too...
*N--
Good Answers: 137
07/03/2008 3:58 AM
I agree with Milo's post #1.
But an elbow is part of a torus. Formula for surface area of a (whole) torus is well known and easy to work out from first principles. Fraction of a torus = φ/360 where φ = nominal angle of elbow (45°, 90° etc).
Cheers........Codey
07/03/2008 7:23 AM
Qatar, many chinese workers work there. I was told.
look at this web site for calculation surface.
http://www.webcalc.net/calc/0046.php
Surface area is commonly denoted for a surface in three dimensions,
the tube radius of a torus, and the radius from the rotation axis of the torus to the center of the tube
torus
03/04/2018 8:52 AM
Hi ,
This is Santhosh Kumarr Mechanical Engineer. Working as a Design & Estimation in HVAC company @ UAE. Here this website is not working. Can i get formulas for HVAC related.
Indonesia - Member - New Member
02/17/2011 6:58 AM
It's a great calculator website
It's mean, for an elbow, the result must be divide by 4
Thanks for nice info
06/11/2011 3:43 AM
Surface area of an elbow, S = ∏2 D R (θ/180),
where,
D = Elbow outside diameter
R = Radius of elbow
θ = Angle of elbow, in degrees
L = Length of center line of elbow = 2 ∏ R (θ/360)
∏ = Constant = 22/7 = 3.14 (created by Ancient Egyptians)
Derivation of equation: S = ∏ D L = ∏ D (2 ∏ R)(θ/360) = ∏2 D R (θ/180)
11/19/2014 10:33 PM
Abdel can this equation be used for a rectangular radius elbow, meaning that the radius elbow is not a pipe but is actually a rectangular shaped ductwork
06/20/2023 9:03 AM
Well, obviously not, if the thing is a <...rectangular shaped ductwork...> instead of an <...Elbow...>.
01/28/2016 7:40 AM
for a square elbow we need to know the angle, height width and inner radius of that elbow
consider w-width, h - height, r- inner radius
the total surface area will be the sum of areas of four sides
=the area of two curved sides + area of inner side + area of outer side
now the area of curved sides will be a1= 3.14( (r+h)² - (r²) )
there are 2 curved sides = a1 x 2
the inner side of the elbow will be a square with width w and we need to find the length
the length l = r x ∏/2 (considering the elbow with 90 degree )
area a2 = l x w
like that area of outer side will be a= L x w
where L = (r+h) x ∏/2
total area A = 2xa1+a2+a3
or A = (2x3.14( (r+h)² - (r²) )) + (( (r+h) x ∏/2) x w)+( r x ∏/2) x w)
Abdel Halim Galala (1); Anonymous Poster (1); AvatarIndo (1); cnpower (1); Codemaster (1); geotom84 (1); Milo (1); NILOBA (1); PWSlack (1); SANTHOSH KUMARR (1); Sparkstation (1)
