Previous in Forum: monitoring pressure room   Next in Forum: Need a manufacturer for wearable pendant timer/vibrator
Controller Tuning
07/03/2008 1:03 AM
I am using a EUROTHERM temperature controller with Auto tune facility. I auto tuned it. However the controller is only giving 10% output during the heating period and takes a very long time to reach the Setpoint of 26 degrees from 20 degrees to start with. The process is a 2 litres alcholol reservoir which is cooled with water whose temeprature changes from 19 degrees to 25 degrees. The heating is used to raise the temperature to 26 degrees. We are tuning only the heating. Cooling is not controlled. Should cooling be done when the controller is tuned for heating. Please guide.
Re: Controller Tuning
07/03/2008 5:54 AM
Check whether the controller is set for direct-acting or reverse-acting as a first step, then re-post below.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
07/03/2008 8:55 AM
Ya, it's probably all in the setup. This instrument may also have an output limiting feature. A complete parameter check is in order.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
07/04/2008 1:57 AM
Sounds like it may be the conservative settings that autotune usually come up with. If you can afford to play with the process a bit you could try some different things. Generally I halve the Proportional Band, double the Integral and get rid of the Derivative to zero. This assumes that your controller uses % and not Gain for Prop Band, MinsPerRepeat and not RepeatsPerMin for Integral. Also assumes you can afford some overshoot of the setpoint ie: SP=26Deg the PV may go up to 30Deg before cooling back down to 26Deg. If you cannot afford overshoot then you will need some Derivative for certain, Derivative is tricky to tune if you are not a seasoned hand.
It sounds like the Autotune has imposed the least responsive curve (which is the cooling curve) to govern the whole controller tuning values.
-ROK-
07/04/2008 2:53 AM
Sometimes (just sometimes) these controllers need an additional line of code in them.
The software will try to use the whole duration of the program step to reach the end point. (Like a ramp function.) The controller will sense the temperature rising and only provide enough input power to reach the SP by the end of the program step.
Suggest you re-write the program with an additional line of duration 1 minute with SP at 26 degrees. (Unless you want it to warm over a longer period.)
Learnt this with our first machine as you never knew what the starting ambient was.
Register to Reply 4 comments
Anonymous Poster (1); Bricktop (1); Just an Engineer (1); PWSlack (1)
