Previous in Forum: Finned/Studded Tubes   Next in Forum: mini truck chassis
9 comments
alternate to FO steam boiler
07/04/2008 6:53 AM
we are looking for an effective and economical alternate solution to the FO steam boiler (3 pass reverse flue smoke tube boler)-2 tonne capacity-
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
Re: alternate to FO steam boiler
07/04/2008 11:01 PM
Would you please give more info,
Do you need 2 tonne
what fuel are you burning
what pressure does your process require
daily or annual use
is it possible that you are using steam ton just make hot water
Let me know and I will help you with some options.
Miketheboilerguy@aol.com
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
07/09/2008 6:11 AM
sir
We are manufacturing ayurvedic medicines with the help of Revotherm ,thermax boiler -3 pass reverse smoke tube boiler -fuel -furnace oil,evaporation =2000 kg/hr,connected load =18.5 kw
ie,a fire tube boiler ,having 700 lts consumption per 9 hours with a PRV to regulate the pressure to 3.5 kg
the price of FO is raising to sky day by day in the range of 35.00(INR)to 40.00
According to indian standards what will be the solution ?-economically,efficiently
satheesh
kerala ayurveda ltd
athani
keralam
india
07/04/2008 11:24 PM
Please excuse my question about fuel I meant to ask what type of fuel oil are you using and can you change to gas? I have completed a lot of burner conversions.
please let me know.
Mike
Good Answers: 19
07/07/2008 12:41 AM
The best & cheapest alternate to Furnce Oil is :
Agro Waste in briquette form.
Next - Powdered Coal with Fluidized Bed Boiler(not applicable in 2 Tph Boiler)
Next: Tyre & Rubber soles (Highest Cal.Value).
Next Rice Husk/ Wood Chips/ Coal in loose form.(If briquetted Cal.Value rises).
Next Natural Gas
Next Diesel Oil
Next LPG Gas.
07/07/2008 4:01 PM
I have contacted the best world wide source for tyre gasification on your behalf. If you have not been contacted in two days please contact me direct and I will directly connect you to the manufacture. Do you have a large supply of old tyres to burn?
Respectfully
miketheboilerguy
Good Answers: 19
07/11/2008 10:54 PM
Please check your email & reply.
07/13/2008 2:44 PM
Has Latif Majoob contacted you about the tyres?
12/25/2009 6:29 AM
The most common type of multi fuel furnace combines a traditional outdoor wood furnace with a fuel oil, propane or natural gas burner. The addition of a fuel burner to the wood furnace can be useful in a number of ways. Although multi fuel capability is standard on most of the larger outdoor wood furnaces, it's an option on less powerful models that will add around 25% to the purchase price. The cost to heat your home with natural gas is less than heating with wood, switching from wood to gas is a simple matter of turning the fuel selector knob.
____________
Greentech are specialists in a range of Gasification Boilers Services
04/29/2025 5:19 AM
Well, what the <...we...> appears to be doing is getting CR4 contributors to do that task.
Invitation declined.
Register to Reply 9 comments
Bob Walsh (1); ducon (2); miketheboilerguy (4); pgsath (1); PWSlack (1)
