Is there a front panel indication on the drive that is telling you there is a ground fault in the system? Is protection tripping? What are the symptoms? Is there any indication whether the fault is on load or line side of the drive?
ALL "electrical" failures are mechanical in nature.
I have seen ground faults recover without much work(occasionally)--Either remake the connections or dry them if they are in a damp environment. Sometime the HMI may go bad, but I don't know anything about your inverter--If all connections are clean and dry and you still have a ground fault, check the motor insulation with a Megohmmeter-DISCONNECT THE DRIVE AND DON'T MEG WITH IT CONNECTED--IT CAN DAMAGE OR DESTROY IT. I start at the drive, because that way you can meg the conductors and motor--If they meg bad go downstream and break connections at the motor and check both ways. If the motor and conductors meg good(sometimes I run the motor across the line to verify it, if possible) then you may have a bad inverter.
If the problem was upstream(I don't think it's likely) then it should show up as a feed fault, and the drive faulting wouldn't remove it and you would be tripping a breaker somewhere.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
