Previous in Forum: Type K thermocouple   Next in Forum: Eurotherm 2408i
Valve Exit Vlocity
07/08/2008 6:42 AM
Hello Frnds
1) Can some one receomend wat should be ideal exit velocity of control Valve , if flowing media is acid gas ( so that downstream piping will not be impinged )
2)Is PTFE suitable for maintaining fugitive emission norms , I have consulted vendor , but not gottta definite answer
Regards
Jose
Re: Valve Exit Vlocity
07/08/2008 7:05 AM
Please describe the gas, its temperature and pressure, and the materials-of-construction of the valve and pipework.
07/08/2008 8:40 AM
Moc For valve IS ASTM 216 GRADE WCC pipeline moc is Carbon steel
Temp 100 DEG F
pressure is 12.9 psig
Application is acid feed gas ( sulfur recovery unit )
Regards
Jos
07/08/2008 10:36 AM
I beleive the question to be a bit incomplete. Certain gases will react with certain materials differently. ie sulfur to carbon in your example - but sulfur what? H2So4, C0S, CS2, H2S etc.
It sounds like maybe you are in a refinery?
I (and correct me anyone) am not as interested in psi so much as I am in reactivity of materials. We have countless gases and chems which we flow at often quite high pressures through stainless steel tubing without concern.
Again I might be sifting the apple cart looking for an orange......
My limited refinery experience was surrounded with black iron piping and sulfur based gases which were maintained at 10-15 psi for exhausting purposes.
As for PTFE: I know that companies such as Parker, who manufacture PTFE components for valves and compression type fittings also produce reference/compatability charts. Most of which that I have seen are pretty inclusive.
07/10/2008 12:33 AM
Thanks for providing info
Regards
jose
Register to Reply 4 comments
josej (2); PWSlack (1); TexasCharley (1)
