Previous in Forum: Safety valve design   Next in Forum: Valve Exit Vlocity
11 comments
Type K thermocouple
07/08/2008 4:52 AM
how to determine type K thermocouple if the two metal is chromel and alumel. which one is positive ?
Re: Type K thermocouple
07/08/2008 5:03 AM
A millivolt meter?
07/08/2008 5:16 AM
without using voltmeter how to determinne which one is positive?
07/08/2008 5:22 AM
According to Wikipedia, chromel is +ve.
07/08/2008 5:38 AM
if chromel is +ve, what is the wire insulation colour code.
your help very much appreciate.
07/08/2008 5:46 AM
If you follow the link to Wikipedia and scroll down the page, there is a table giving IEC, BS and ANSI colour codes.
07/08/2008 6:01 AM
thank you JohnDG
07/08/2008 7:44 AM
You will find for type 'K' thermocouple that the chromel wire is magnetic, so a simple magnet will identify the wires.
I think (might be wrong though)
07/08/2008 8:37 AM
Useful tip (if it works!). Anyone got one to try?
07/08/2008 9:36 AM
Yep! I remembered correctly, I've just tried it and the nickel/chrome wire is magnetic, other one isn't...
Back in the late 70s we used to use this method when we made thermocouple sensors...
John.
07/08/2008 9:40 AM
Alumel is magnetic(negative), this is one of the reasons why I and some of the other instrument techs where I work carry pocket screw drivers with a magnet tip. In the U.S. and Canada red is always negative but not always magnetic. Thank you
"The older I get -The better I was"
07/09/2008 12:08 AM
alumel is magnetic(negative) i had this many time, when the insulation melt with high temperature. i use my screw driver with magnet tip. to check which one wire is magnetic. in ANSI color code red is negative(alumel)
Anonymous Poster (4); Electroman (2); JohnDG (3); PWSlack (1); wrenchpuller (1)
