Previous in Forum: Coax Valve enlightenment   Next in Forum: thermocouple type K
thermocouple cable
07/08/2008 8:51 PM
thermocouple cable, if the thermocouple cable come with screen wire, is't okey if i connected the screen on both end, one side connected to the junction box and the other side connected to FTA card. any problem will occur if connect both side?
Re: thermocouple cable
07/09/2008 3:20 AM
It is inadvisable in some circumstances to earth both ends of a cable screen. "Ground loops" can occur and cause distress. The phenomenon is most marked and best studied in analog audio microphone and gram pickup circuits, where "mains hum" can be a blessed nuisance and spoil the music.
07/10/2008 9:18 AM
It is not recommended to connect a thermocouple screen wire to ground on both ends.
The industry best practise is to connect it to the instrument ground in the controller cabinet since you are assured of a healthy ground at the cabinet.
The ground in the field can corrode or become ineffective especially if the junction box is iro/metal and there is formation of oxides ( rust) etc.
As you may know ,thermocouple signals are in the order of very low level millivolts and any noise can result in unwanted results.
07/12/2008 12:14 AM
Check if you have a grounded or ungrounded t/c if it is in a sheath
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); z28summit (1)
