Previous in Forum: thermocouple type K   Next in Forum: ORIFICE PLATE CALCULATION
honeywell TDC 3000
07/09/2008 5:46 AM
hi there, for honeywell TDC 3000, what kind of software using for programming or building point. any one can help please. thank you.
Re: honeywell TDC 3000
07/09/2008 6:41 AM
Honeywell will no doubt have proprietary software that does this.
07/10/2008 11:15 AM
If you register at Honeywell, you can get access to the manuals in a pdf format.
Here is the direct link to TDC-3000 on Honeywell's site, sometime it can be a chore to get where you want to be on their website.
http://hpsweb.honeywell.com/Cultures/en-US/Products/Systems/TDC3000/default.htm
Here is a link which may help while you wait on the registration process to finish.
http://www.omniflow.com/support/technicalbulletins/980201.pdf
This should get you started:
Good luck!
Bill H.
07/10/2008 10:32 PM
Hi, I work as a conventional field tech, our DCS group (they were all conventional techs at one time) does the programing and point building,occasionally we, the field techs do it as well, the few times that I've done it I did it from an US console(key or password is required) there was no software needed and is fairly simple to build a point. I apologize because I don't have all the steps memorized,but it is a matter of going thru the menus. Thank you
"The older I get -The better I was"
12/31/2008 10:52 AM
Hi - I have some procedures you can have on building points - drop me an email at tim.haywood@khalda-eg.com and I'll email them through to you.
Bill H. (1); PWSlack (1); tlh (1); wrenchpuller (1)
