Previous in Forum: Corderite in Ceramics for Electrical Fuses   Next in Forum: Gas Plant Resources: HYSYS and GPSA
10 comments
Better Plaster of Paris
07/11/2008 6:35 AM
how to increase the strength & curing time of plaster of parise with alfa grade
Re: plaster of parise
07/11/2008 7:31 AM
Add cement dust?
Re: Better Plaster of Paris
07/12/2008 6:09 AM
I don't know if this works, as I have never tried it myself, but adding an acrylic primer (primer made for concrete, to make it bond better to the surface, hey'di makes them in Norway) is supposed to make plaster stronger. Another option is to mix in chopped strand fibreglass, or buy a plaster with chopped strand allready mixed in.
The curing time of plaster is dependent on temprature, so if you try to keep the room and the mix cold, the curing time will increase. However there are several types of plaster and if you contact a proper muolding/arts supplier, they should be able to help you find a type with your prefered setting time. If not, it could be an idea to try adding in a concrete retarder, although that is a wild guess, and will take some experimenting on your behalf.
Good luck
I am the workshop king, I can make anything...
Good Answers: 97
07/12/2008 12:28 PM
Add "Elmer's Glue" to the mix
07/14/2008 3:31 AM
Which one: they appear to sell all sorts?
Good Answers: 97
07/14/2008 2:09 PM
The original type
is water soluble.
07/15/2008 2:18 AM
That looks like a PVA glue: so in India Fevicol is probably the best known brand.
Shankar, What did you mean when you said: "with alfa grade"?
07/16/2008 12:07 AM
hai Randall,
Basicaly in india there are verious of grades of plaster of parise alfa,beta are well known grades used in cement,medical industries.i have only some datas on alfa grades and the combination of alfa depends as per customer's requirement.
i am addding the spec which i have with me fro your knowledge
Parameters
Specifications
Plaster of Paris Grade Alpha
Plaster : Water ratio 100 ; 50
Retention on 120 mesh 0.9%
Mixing, Soaking and blending time 5 Minutes
Initial setting time by Vicat apparatus 21 Minutes
Final setting time by Vicat apparatus 32 Minutes
Rise in Temperature 11 Deg C
Modulus of Rupture - Dry 82 K.Gms/sq.cm
Bulk Density 1.15Gms/cc
Regads
Shankar.n
Good Answers: 97
07/18/2008 2:27 AM
Hello shankar.n:
I think I think you may use hemp fibers to strengthen plaster of paris.
To decrease set time you may add (experiment with this) calcium nitrate
as a catalyst.
07/18/2008 4:26 AM
I suppose it depends on what you're trying to do: you might get some ideas from this other thread if you don't have to stick (no pun intended) with plaster of paris:-
http://cr4.globalspec.com/thread/23767/Material-for-a-good-Quality-toy-without-Lead
Polymorph plastic is used in medical applications.
Milliput as suggested by Thornpile looks good, but, would be expensive in large volumes.
Good Answers: 97
07/18/2008 12:11 PM
Click on this link Enquiry
Register to Reply 10 comments
bwire (4); PWSlack (1); Randall (3); shankar.n (1); Thornpile (1)
